Spacer plates for the head
Old Oct 17, 2004 | 02:49 PM
davidnormanuk's Avatar
davidnormanuk
Default Spacer plates for the head
Hi all,
Just wondered if anyone knows of a place that makes spacer plates for the RS Turbo?
My problem is that my head has been skimmed too much and I need a spacer plate to correct this problem.
Dave
Old Oct 17, 2004 | 05:21 PM
TILLIO's Avatar
TILLIO
Be better off starting again with another cylinder head, the more gaskets/plates between the block/head will just be asking for problems/failiures
Old Oct 17, 2004 | 05:46 PM
KSA-Cossie's Avatar
KSA-Cossie
or get a copper gasket.
Old Oct 18, 2004 | 08:54 AM
davidnormanuk
Where can I get a copper gasket from. Would this do the job?
Dave
Old Oct 18, 2004 | 05:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Check this months performance ford m8.
Old Oct 18, 2004 | 05:40 PM
davidnormanuk
Found a place that make spacer plates up.
http://www.gosnays.co.uk/
£35 + vat & postage.
Old Oct 18, 2004 | 08:05 PM
Hardeep_Singh's Avatar
Hardeep_Singh
ferriday (spelling) do the copper plate that is featured in pf, i was gunna do this but karl norris advised me not to he also wouldnt set my car up with it so i just put everything back together. on the other hand i know someone who has it fitted and hasnt had any problems yet and there running 20psi through the engine
HTH
Old Oct 20, 2004 | 07:55 PM
NEO™®©'s Avatar
NEO™®©
just get another head you can pick standard ones up for like 50-70 quid
Old Oct 21, 2004 | 11:26 AM
Wazzzer's Avatar
Wazzzer
I've got one you can have for £30 + postage
RB26DETT
Feb 5, 2022 01:54 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
Si B
Sep 12, 2015 06:49 AM
