Door wont close
Old Jan 29, 2004 | 04:36 PM
Default Door wont close
My door wont shut on my series 1. Could it be the catch and if so what catches are the same. Series 2 or xr3i or standard mk3 cheers any help appreciated
Old Jan 29, 2004 | 06:09 PM
3door's Avatar
3door
u have prob flicked the catch by mistake if u go to the catch and flick it back the opposite way the door will close again
Old Jan 31, 2004 | 07:03 AM
Nope its not that it doesnt stay if you flick it closed with the door open like the other side. is my catch broken and which ones fit (series 1 custom with c/l) cheers
Old Jan 31, 2004 | 02:11 PM
if its the catch thats gone any mk3 catch should fit, but just the catch and use your oen lock and linkages m8 HTH
Old Jan 31, 2004 | 02:47 PM
I did this to my sierra when fitting a new door. While adjusting the height ofthe door I slammed it and snapped the plastic plate in the catch area. It then wouldnt shut and when I looked I found I had snapped part off.
I had a spare door so took the catch mechanism out and put that in and didnt slam it so hard until the height was right after! Was a bit fidly to switch but cured the problem.
Hope it helps
155lee
Oct 24, 2015 11:11 AM
Vacuman
Sep 22, 2015 12:09 PM
Vincereese
Sep 18, 2015 12:48 PM
Vincereese
Sep 18, 2015 12:47 PM
Mark V8
Sep 13, 2015 09:34 AM
