Gearbox whine
Old Feb 17, 2008 | 08:11 AM
Default Gearbox whine
Does anyone know if there is oil that will stop noisey gear boxes. First gear in my cossie whines a bit. I was just wondering if you can buy anything to quieten them down. Or is it new gear box time.
Old Feb 17, 2008 | 08:18 AM
Try some GREASED LIGHTNING.
Old Feb 17, 2008 | 08:33 AM
Where abouts can you get that from and do you just pour it in the gearbox with the orginal oil.
Old Feb 17, 2008 | 02:10 PM
mechanic28's Avatar
mechanic28
yer just put in with the oil might be worth changing your oil at the same time not sure where u get it from last time i used forte one which was quite good also used the stp stuff which aint bad!
Old Feb 17, 2008 | 02:32 PM
KSA-Cossie's Avatar
KSA-Cossie
Isn't that stuff for auto's ?
Old Feb 17, 2008 | 02:44 PM
mechanic28's Avatar
mechanic28
which one?both the ones i used was for manuals
Old Feb 17, 2008 | 02:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Sorry,the greased lightning stuff.
Old Feb 17, 2008 | 04:13 PM
Greased Lightning, for manuals used in my T5 box with GEAR oil, and in a rover r380 manual box with no problems.
Old Feb 17, 2008 | 08:07 PM
Will it be ok for the 4x4 gearbox is it the name of the box mt75. Also what oil does it take. Will 75/90 be any good or do you have to use proper old for the gearbox.
Old Feb 24, 2008 | 03:41 PM
I was in halfords today and i was looking though the gearbox oil list which was hanging up. It said in there to use a castrol oil. So i looked on the back of the castrol oil bottle and its oil grade is 75/90. I work in a garage so i might as well pinch some oil from work for my car. The oil i use at work is 75/90 fully sythetic.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
