Ford Range This section is for other models in the Ford range.
Why 1.6 cvh has the same BHP as 1.8 zetec?
Old Feb 16, 2008 | 07:03 PM
Maki's Avatar
Maki
Default Why 1.6 cvh has the same BHP as 1.8 zetec?
MK4 xr3i had 105 BHP... later in MK5 there where 1.8 zetec engines with the same BHP? So what was the point in introducing that new engine?
Old Feb 16, 2008 | 08:26 PM
sexr3i's Avatar
sexr3i
isn't it
catalytic converters, noise and EGR robbed the zetec. CVH in similar state of tune would be 80ish?
130 spec zetec put in a mk4 with mk4 emissions laws to beat and you'll see 145+bhp easy, and it revs smoother, doesn't leak, and won't start tapping 3 weeks after you bought it.
Old Feb 16, 2008 | 08:34 PM
XR2's Avatar
XR2
1.6 CVH was available from ~70 hp up to 132, N/A up to 115 hp, 1.8 Zetec was available N/A 105 - 130 hp. It has more potential, but as mentioned, it could do better...
Old Feb 17, 2008 | 08:21 AM
Wardy257's Avatar
Wardy257
The ZETEC was supposed to be a lean burn carb engine but a last minute EU law change forced it to go EFI. Ford rushed the development of the EFI and the engines are slightly low powered as standard. But give me a 105 bhp ZETEC over a 105 bhp CVH any day, there is more to an engine than bhp.
Take the 130 PS spec 1.8 ZETEC and add Twin 40m TBs and you have 160 bhp.
Take any spec CVH add Twin 40m TBs and you have 120 bhp max.
Old Feb 17, 2008 | 08:39 AM
Maki's Avatar
Maki
At the moment I was thinking to use one of these engines in my MK4 cabrio... and as I looked to the BHP figures and costs of parts for the engine I was thinking of going 1.6 CVH way as I have plenty of spares from my old MFI and carb CVH engines... and the rebuild of the engine would cost less as there is only one cam and twice as less of all the other bits like falowers etc.
So what would be your choise? CVH bolts on easier and I could get the engine with everything needed for say 70 GBP... other way is to get MK5-6 wth 1.8 zetec (105) and swap everything without all the emission stuff for lets say 120 GBP, but with burning oil effect...
What would you do if you where in my place? Also I'm in some economy for everyday driving to work, so I quess 1.6 would eat less?
I could live with thouse leaks if that's the only problem...
Old Feb 23, 2008 | 11:02 AM
gingerxr2's Avatar
gingerxr2
cvh anyday,ive had mk2 xr2's for 10 years and have never had engine trouble,cheap,reliable,currently got an xr2 RR at 128bhp,on single carb,stg2 head,but its your car yourt choice,everyone i know whos gone zetec spends more time fixing than driving,i know what id do
Old Feb 23, 2008 | 03:40 PM
Wardy257's Avatar
Wardy257
Thats coz most people bodge it. Change the oil (using the correct oil helps a lot!!!!) every 10k and the ZETEC will go for 150k+
Find a 130 bhp spec ZETEC and you can ne sorted for about Ł150. The fuel you will save alone over a CVH will soon pay for it.
Old Feb 24, 2008 | 04:48 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
ive always had cvhs and now i have a zetec in my orion
2 litre with a few mods,i would never go back,its taken 10k of hard abuse over the past year and has never caused me a problem,and it also does good mpg,lol
Old Feb 24, 2008 | 07:35 PM
sexr3i's Avatar
sexr3i
isn't it
cvh anyday,ive had mk2 xr2's for 10 years and have never had engine trouble,cheap,reliable, everyone i know whos gone zetec spends more time fixing than driving,i know what id do
I was gona post but thats basically the exact opposite of my personal experience. So I'll leave it at that. lol.
Old Feb 27, 2008 | 10:42 PM
mercury xr's Avatar
mercury xr
thinking of putting a zetec in my xr3i efi
what would be best way to do this, just zetec bottom end? full zetec block?
Old Feb 28, 2008 | 07:37 PM
sexr3i's Avatar
sexr3i
isn't it
full zetec engine and management.
Old Feb 28, 2008 | 07:56 PM
mercury xr's Avatar
mercury xr
Sexr31 - your on XROC aren't you, have you got a thread on your conversion?
Old Feb 29, 2008 | 12:02 PM
sexr3i's Avatar
sexr3i
isn't it
yes mate, there's loads on there. do a search for zetec conversion.
Old Nov 9, 2010 | 08:52 AM
Luke Thomas 95's Avatar
Luke Thomas 95
Blaze Your Own Trail
i Have a 1.6 L Mk4 with CVH , whats the best Carbs to put on? 40DCOE , 45 DCOE ect. ? ty
Old Nov 10, 2010 | 09:28 PM
dandannydandan's Avatar
dandannydandan
I don't know between them two but have you thought of bike carbs?
Old Sep 11, 2011 | 11:31 PM
MrEngineerdat's Avatar
MrEngineerdat
1.8cvh man...
i did it.
1.8 sierra lump, long throw on the crank and slightly taller block
fat helping of silicone on the xr sump to fit 1.8
xr head, ported/polished, standard cam, holes redrilled to fit 1.8 bolts, heavy skim for compression
reworked xr3 exhaust man
reworked xr3 inlet man
turbotechnics carb and mech pump, although not running forced induction
xr2 ignition advance with the dizzy
lightened resurfaced flywheel
i reworked my conrods and pistons myself removing about 2oz of metal on each one and improving piston lubrication. good digi scales are needed
rebored to 1.82
so its all lightened and balanced and bored out and gas flowed except the cams and sicko fuel setup and this only set me back a few hundred quid in total
quite confident i had 140hp maybe a bit more but it had lots more torque
the longer throw crank made it an under square design so its better at making torque than horses. also 8v is less drag than that of a zetec so makes good power even when its not being caned. good milage can be achieved this way too.
i used to launch in second gear like it was first gear and get squeaks out of third in the dry. 60 came up in one hit without a gear change. about 5 to 6secs and thats without a good cam. i was maxing out at 130mph
nobody believes me but i''l tell you anyway... i got 75miles to the gallon going to yorkshire.
im sure if i sorted th fuelling out properly i could have gotten 160hp all for the price of itb's on a standard engine.
or if a turbo and intercooler was fitted it not unreasonable to expect 200hp.
but - from reading quarter mile times the most effective was around 150hp. the high power turbos had traction issues to 60
go cvh all the way mate theyre a very simple and yet effective design and theres so much stuff available for them. remember theres less bits to go wrong on cvh.
a zetec has many of the attributes of a cossie engine but it just isnt as good so why bother with it. the standard stuff goes really well if its worked on
Old Sep 12, 2011 | 12:00 AM
MrEngineerdat
also later on i fitted solid lifters to rev it to bits.
it was good but it shredded the just-run-in standard big ends. so i fitted some high performance ones and it handled 8000rpm a few times. i was worried about poor oil supply at this speed but it took it. never got a high speed run like this but cant imagine it would be any different
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
talon1
Sep 15, 2015 10:27 AM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
