Ok need help..........With vid.
Old Feb 16, 2008 | 04:20 PM
lawnsy's Avatar
lawnsy
Default Ok need help..........With vid.
Right if you seen my post further down the page i thought my turbo was gone as i was out in the car this morning and it started to smoke mainley at tickover and cleaed when driving.....but as i had the kids in i did not put me foot down......
So i just been out and checked the turbo and there is no play at all and no oil in the pipes.....totaly dry..
So i went to give it a bit death to see if the smoke cleared and as soon as the car comes on boost it just loses all power but runs mint off boost and at tick over.....but the car boosts normaly as it should but just no go just all noise......if you know what i mean....
now i thinking that it is not getting the fuel that it needs....
AAAGGHHH CCAARRSS...well cossies
anyhow here the vid i took....
Old Feb 16, 2008 | 04:26 PM
Dan's Avatar
Dan
Don't know mate but you need to put a lock on your photobucket account!
Old Feb 16, 2008 | 04:27 PM
JamesH's Avatar
JamesH
You also have no fuel and your ABS light is on to add to your woes
Put some fue in, any different?
Have you checked the usual CPS etc?
Old Feb 16, 2008 | 04:29 PM
lawnsy's Avatar
lawnsy
how i do that like?
Old Feb 16, 2008 | 04:31 PM
lawnsy's Avatar
lawnsy
just had a look its only got me old cars n bikes so nowt i would not share...lol
Old Feb 16, 2008 | 04:41 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u need to drive my car.................it picks up better than urs......honest on a t38
Old Feb 16, 2008 | 04:49 PM
lawnsy's Avatar
lawnsy
fuel never bothers it,....can run it right down and it normaly goes ok still and the abs sensor is the drivers front....just carnt be arsed to do it yet,,,,
pete that was in 3rd gear......and it does normaly pick up better but i just getting a load of noise and no go at all......
Old Feb 16, 2008 | 04:51 PM
lawnsy's Avatar
lawnsy
not checked the cps as there is no miss just when it comes on boost the boost gauge goes up but the car just still drives like it got no boost if ya know what i mean
Old Feb 16, 2008 | 04:54 PM
bud-weis's Avatar
bud-weis
Football Cwazy
any cracks in the downpipe or exhaust housing?
Old Feb 16, 2008 | 05:07 PM
Drewman's Avatar
Drewman
A lot of crash pics, not had much luck?
What's going on here?
Old Feb 16, 2008 | 05:14 PM
BM08's Avatar
BM08
bit of an "off" on some black ice?
Old Feb 16, 2008 | 05:23 PM
lawnsy's Avatar
lawnsy
that was bigern's car off here after he crashed it...i bought it for bits and busted it.....
Old Feb 16, 2008 | 05:26 PM
lawnsy's Avatar
lawnsy
na none.....whats the best way of checking the flow rate from the pump....im thinking pump or blocked filter......cause its always started the first turn of the key and a couple of times this week ive had to crank it for 2-3 seconds as if it had no fuel......
Old Feb 16, 2008 | 07:28 PM
lawnsy's Avatar
lawnsy
up..........
im thinking=
fuel pump / filter
map sensor....
Old Feb 16, 2008 | 07:32 PM
BigErn's Avatar
BigErn
Ouch, it hurts to see those pics.
See my sig for how it used to look.
Lawnsy mate, have you checked voltages to the pump incase the wiring is breaking down or poor connection.?
Old Feb 16, 2008 | 08:39 PM
Dicko&Vacant's Avatar
Dicko&Vacant
dont look or sound to clever that lawnsy lol dont think thats owt to do with fuel tbh
Old Feb 16, 2008 | 08:43 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
sounds like a map sensor prob to me, or the ECU water temp sensor. What colour is the smoke?
Old Feb 16, 2008 | 08:59 PM
RAT8OY's Avatar
RAT8OY
I agree it looks like map sensor sort of thing but have you checked your intercooler and boost pipes for leaks/splits?
Phase sensor?
Good luck anyway!
Old Feb 16, 2008 | 09:45 PM
BigErn's Avatar
BigErn
Phase sensor changed, I think he did it today anyway. Could be set wrong??? MAP sensor is another of the things we suspect too. Hmmmmm. Anyone local got one we could rob for half an hour??????
Old Feb 16, 2008 | 10:02 PM
Dicko&Vacant
ian ive got a spare 3 bar kicking about if he wants to pop down and try it
but tbh if it was map sensor it would cough and splutter on tick over etc well mine did when last mp sensor fooked up
just give me a bell tomorrow if needs be
Old Feb 17, 2008 | 12:25 AM
BigErn's Avatar
BigErn
cool bud Ill tell him or he will find out if he reads this
Old Feb 17, 2008 | 08:14 AM
lawnsy's Avatar
lawnsy
did not change the phase sensor....
Old Feb 17, 2008 | 08:36 AM
lawnsy's Avatar
lawnsy
how can i check the map sensor....?
what pins on the ecu?
what readings should i get?
i need my power back.....
Old Feb 17, 2008 | 09:10 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
Mine was similar when the pipe popped off the map sensor, also check for splits and cracks on said pipe m8.
Steve
Old Feb 17, 2008 | 12:27 PM
lawnsy's Avatar
lawnsy
Steve
Yip checked it mate it was my first thought that i may of blow the pipe off eather the dump valve, fuel pressure, or map sensor but they all seem ok...
Old Feb 17, 2008 | 08:33 PM
JamesH's Avatar
JamesH
Seems almost like surge??
Old Feb 22, 2008 | 07:49 PM
BigErn's Avatar
BigErn
Check the timing again!
Need to get the bottom pulley off and check the woodruff key mate.
Rod-Tarry
Feb 3, 2015 08:51 PM
Bi22le
May 21, 2011 07:17 PM
Miller 3
21
Nov 2, 2010 10:43 PM
