90' Escort (Heater Problem)
Old Feb 16, 2008 | 02:53 PM
codhead17's Avatar
codhead17
Default 90' Escort (Heater Problem)
Hi guys picked up a 1990 Series 2 RS Turbo last week on the drive home I turned the heaters down as I was cooking.. turned them for some cold air now when I turn back to heat there is nothing warm coming out whatsoever.. the cold mornings are making things a touch frosty. I am thinking heater pipe of connector rod off somwhere???
Old Feb 16, 2008 | 05:21 PM
tonyrally's Avatar
tonyrally
passionford god
sounds like the outer part of the cable isnt atached so the cable will pull but not push try adjusting the cable manualy by hand if u can reach the lever thanks tony
Old Feb 16, 2008 | 05:24 PM
As said sounds like the cable or clip on the end may have come off, most likely at heater box end.
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
