Rear disc conversion
Old Feb 16, 2008 | 10:43 AM
Billy_RS's Avatar
Billy_RS
Default Rear disc conversion
Who's done one?
What do you need to do it and did you have any problems?
Old Feb 16, 2008 | 12:20 PM
xrmalin's Avatar
xrmalin
Ive done it on my 3i i cant tell you how well it works yet as i havnt driven the car yet
I got the brackets of a bloke on ebay but after looking at other peoples there all of a similar design.
sierra cossie 2wd calipers as i wanted the solid disc's & a mk5 rs2000 hand break cable.
This is how the bracket fits to the hub we had to nick a couple of the corners off the bolts so the hub cleared properly.
We bolted the disc on mounted the caliper to measure for the spacers to make sure it sat in the center over the disc made the spacer & bolted it all up
(the caliper should be mounted the oposite to the picture it was just put on for the picture)
I put all new brake lines on through my project so i dont know how you would go about doing them hope this helps.
Old Feb 16, 2008 | 12:26 PM
Billy_RS's Avatar
Billy_RS
Thats brilliant mate
Thanks alot
Old Feb 16, 2008 | 02:13 PM
Aaroncast's Avatar
Aaroncast
dont forget the bleeding!!!! /caliper postion when doing them-nipple on top !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 16, 2008 | 09:57 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I have a kit Billy
Old May 21, 2016 | 05:25 PM
G999 YLU's Avatar
G999 YLU
Hi
Please help
I think that's where me and my mate went wrong today ??
The Calipers say L and R on them but when mounted the bleed nipples are the bottom ?
So they are wrong then ?
Regards
Les
Old May 21, 2016 | 07:13 PM
nigel b's Avatar
nigel b
thats fine
unbolt the caliper and slide it to the other side of the disc to bleed it
Old May 22, 2016 | 08:40 PM
Cossy Mike's Avatar
Cossy Mike
Who sells the brackets now?
yatta
May 21, 2016 10:31 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
cossirob
Sep 3, 2015 09:17 PM
