can you strip a cossie starter motor apart?
mine sticks since the oil line to the pressure gauge leaked and filled the starter with oil
sick of not being able to start the car unless i have a mate and the trolley jack handle present
or am parked on a hill!! so its coming off now
yes matt, just unbolt the solinoid, split the casing then remove the windings and clean everything,dont use grease as lubricant as the clutch dust will stick to it use graphite instead.
it is usually the the shaft that the gear throws out on the causes the problem.
regards
steve
regards
steve
ta for info
maybe emptying the stack of oil out of it helped
just replaced trigger wire terminal and cleaned up everything and replaced and its just done 10/10 starts
brom, aint about being tight, how can i be tight about something i didnt know
fuck it!! its raining but im off out in it now
not really, up and starting though lol
need to fetch the rack off browney and fit that, get the box reconned, remove back plate remove any shit re-fluid and fit this spare diff and prop, and no doubt something else will break in the mean time so add that unknown to the list
getting annoyed with not driving it now so if it breaks it breaks
Mc5506
Oct 5, 2015 09:57 PM
