Fitting new head onto engine
Old Feb 11, 2008 | 08:19 PM
vibrating_cake's Avatar
vibrating_cake
Default Fitting new head onto engine
Right, ive recently purchased a big valve cylinder head for my engine (ford pinto 2.0) including cam etc etc etc
and im wanting to fit it, is it just a case of removing inlet manifold including carb (after bleeding coolant)
removing exhaust manifold
removing head.
puttin back being the reverse while replacing each gasket on the way??
or do i have to buy new head bolts or something??
help much appreciated
Old Feb 11, 2008 | 08:28 PM
IAIN ABZ's Avatar
IAIN ABZ
the Pinto head bolts are stretch bolts and should be renewed everytime- by the book, i know people who have re run the bolts but i would not recommend it
May as well replace the timing belt and tensioner whilst u are doing it too
Old Feb 11, 2008 | 09:43 PM
vibrating_cake
thanks!
Old Feb 12, 2008 | 04:03 PM
Use a FELPRO BLUE head gasket, as these are extremely good, and what I used on my own pinto's.
Old Feb 12, 2008 | 06:09 PM
vibrating_cake
*hopes ur online*
FR32 cam or FR30 cam for an everyday car....
i cant decide
the FR30 quotes a powerband from 1k-6k
the FR32 quotes a powerband from 2.5k-7k
fr32 is a slightly higher lift and a longer duration.
any comments on these cams... for the pinto+type 9 gearbox (loooong)
Old Feb 13, 2008 | 08:41 AM
I have never used these cams, as had ones ground for me as high torque cams(auto!!).
I would personally go for the 30, unless going to further mods then it would be 32.
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
