quickshift grinding on a t5 box
Old Feb 10, 2008 | 08:14 PM
155lee's Avatar
155lee
Default quickshift grinding on a t5 box
hi,i bought a quickshift for my 2wd coss from the states,it cost pennies compared to what you would buy 1 for here.i fitted it and now it makes a grinding noise when driving.i have adjusted it and it seems to do it worst in fifth.i didnt use the nuts and threaded bar they supplied as i was lying under the car and the old bolts were easier to reach.im going to put the supplied bolts in this week and see if it makes any difference.it definately didnt make this much noise before!has anybody else had this bother and what did you do to cure it?cheers,lee
Old Feb 10, 2008 | 08:16 PM
rapidcossie's Avatar
rapidcossie
the bit where you say it costs pennies makes me think its junk.
I used a quick shift on two T5 boxes for years and had very little trouble at all.
It did cost almost 200 quid to buy tho.
Old Feb 10, 2008 | 09:09 PM
Norwegian Wolf's Avatar
Norwegian Wolf
Does the sound change when you press the gearchanger sideways while driving?
Old Feb 10, 2008 | 09:16 PM
col cos1's Avatar
col cos1
i use one and no issues except you can beat the syncros changing too fast
kind of makes it pointless
Old Feb 10, 2008 | 09:26 PM
155lee's Avatar
155lee
yes,if you push it forwards in fifth,or pull it sideways the noise gets quieter,is that a clue?cheers,lee
Old Feb 11, 2008 | 07:39 AM
It suggest that pressure exerted from the new lever is the cause.
Old Feb 11, 2008 | 11:26 AM
Norwegian Wolf
I have a B&M shortshift mounted on my T5.
It was mounted before i bought the car..
And it makes a weak sound, and it changes if i press the shifter sideways while driving. Mostly in 2nd and 3rd gear.. I can barely hear the sound in other gears, but its there.
Is it a possibility that it's the shortshift that is mounted wrong or something, and the gearbox is fine?
I have no problems at all with the gearbox, its smooth and free from sounds..
Old Feb 11, 2008 | 12:47 PM
cossie604's Avatar
cossie604
Got my B&M quickshift from the states also...same as the ones sold over here but for well under half the price, with no problems what so ever.
Old Feb 11, 2008 | 04:27 PM
155lee's Avatar
155lee
exactly,just because its cheap doent mean its junk.
Old Feb 11, 2008 | 07:34 PM
Ridgey's Avatar
Ridgey
T5's don't like being rushed as someone already mentioned.
Does make them not really worth it.
Old Feb 11, 2008 | 08:36 PM
155lee's Avatar
155lee
i just liked the shortness of the stick compared to the crowbar sized stick ford put in there,i dont have the boot on it yet and its cool to look at too!
Old Feb 11, 2008 | 09:15 PM
Norwegian Wolf
But is it possible that the shortshift isn't correctly mounted?
Since the sound is changing when i press the stick sideways?
Smooth gearing, no problem getting it in gear etc.?
Sorry 155lee, for steeling your tread.
But seems like we have the same problem...
Old Feb 11, 2008 | 09:31 PM
155lee's Avatar
155lee
no bother,the supplied threaded bar and nuts allow the shifter to be adjustable,i didnt use them through lazyness,now im going to have to do it all over again!ill maybe do it tomorrow night and post up how i got on!
Old Feb 12, 2008 | 11:14 AM
Norwegian Wolf
Yes, please let us know how it effected the sound in the shifter
Old Feb 13, 2008 | 10:34 AM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
if it doesn't have the vibration damper on the stick it will sound like the box is fucked, I've welded them up without the damper when i've snapped them and you think did i fuck the box too
and if you don't have the boot on it makes it sound terrible also I had a stripped out car, it sounded terrible without the rubber boot on it put it on and a lot better.
HTH
Old Feb 13, 2008 | 05:48 PM
155lee's Avatar
155lee
yeah,its really whiney and sounds fucked,im going to tackle it tonight i think!cheers,lee
Old Feb 14, 2008 | 06:46 PM
155lee's Avatar
155lee
think when i take it apart ill not put the quickshift back on,the t5 is notchy enough without it,ill cut down and rethread the original stick.i drove it for 15 miles today and it really pissed me off.
Old Feb 14, 2008 | 09:53 PM
cossie604's Avatar
cossie604
Personaly, i'll love my quickshift. Nice and precise with a race car clicky feel. No doubt i'll be changing my mind when I stripping the box down for new syncros
Old Feb 15, 2008 | 07:33 PM
155lee's Avatar
155lee
drove it again tonight,i loathe its clicky notchy feel and the fact i cant use fifth because its too noisy,it was cool to start with,just like a dump valve is,now its irritating
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
20/20 vision
Sep 29, 2015 09:25 PM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
