quickshift grinding on a t5 box
Old 10-02-2008, 08:14 PM
155lee
155lee's Avatar
Default quickshift grinding on a t5 box
hi,i bought a quickshift for my 2wd coss from the states,it cost pennies compared to what you would buy 1 for here.i fitted it and now it makes a grinding noise when driving.i have adjusted it and it seems to do it worst in fifth.i didnt use the nuts and threaded bar they supplied as i was lying under the car and the old bolts were easier to reach.im going to put the supplied bolts in this week and see if it makes any difference.it definately didnt make this much noise before!has anybody else had this bother and what did you do to cure it?cheers,lee
Old 10-02-2008, 08:16 PM
rapidcossie
rapidcossie's Avatar
the bit where you say it costs pennies makes me think its junk.
I used a quick shift on two T5 boxes for years and had very little trouble at all.
It did cost almost 200 quid to buy tho.
Old 10-02-2008, 09:09 PM
Norwegian Wolf
Norwegian Wolf's Avatar
Does the sound change when you press the gearchanger sideways while driving?
Old 10-02-2008, 09:16 PM
col cos1
col cos1's Avatar
i use one and no issues except you can beat the syncros changing too fast
kind of makes it pointless
Old 10-02-2008, 09:26 PM
155lee
155lee's Avatar
yes,if you push it forwards in fifth,or pull it sideways the noise gets quieter,is that a clue?cheers,lee
Old 11-02-2008, 07:39 AM
It suggest that pressure exerted from the new lever is the cause.
Old 11-02-2008, 11:26 AM
Norwegian Wolf
I have a B&M shortshift mounted on my T5.
It was mounted before i bought the car..
And it makes a weak sound, and it changes if i press the shifter sideways while driving. Mostly in 2nd and 3rd gear.. I can barely hear the sound in other gears, but its there.
Is it a possibility that it's the shortshift that is mounted wrong or something, and the gearbox is fine?
I have no problems at all with the gearbox, its smooth and free from sounds..
Old 11-02-2008, 12:47 PM
cossie604
cossie604's Avatar
Got my B&M quickshift from the states also...same as the ones sold over here but for well under half the price, with no problems what so ever.
Old 11-02-2008, 04:27 PM
155lee
155lee's Avatar
exactly,just because its cheap doent mean its junk.
Old 11-02-2008, 07:34 PM
Ridgey
Ridgey's Avatar
T5's don't like being rushed as someone already mentioned.
Does make them not really worth it.
Old 11-02-2008, 08:36 PM
155lee
155lee's Avatar
i just liked the shortness of the stick compared to the crowbar sized stick ford put in there,i dont have the boot on it yet and its cool to look at too!
Old 11-02-2008, 09:15 PM
Norwegian Wolf
But is it possible that the shortshift isn't correctly mounted?
Since the sound is changing when i press the stick sideways?
Smooth gearing, no problem getting it in gear etc.?
Sorry 155lee, for steeling your tread.
But seems like we have the same problem...
Old 11-02-2008, 09:31 PM
155lee
155lee's Avatar
no bother,the supplied threaded bar and nuts allow the shifter to be adjustable,i didnt use them through lazyness,now im going to have to do it all over again!ill maybe do it tomorrow night and post up how i got on!
Old 12-02-2008, 11:14 AM
Norwegian Wolf
Yes, please let us know how it effected the sound in the shifter
Old 13-02-2008, 10:34 AM
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
if it doesn't have the vibration damper on the stick it will sound like the box is fucked, I've welded them up without the damper when i've snapped them and you think did i fuck the box too
and if you don't have the boot on it makes it sound terrible also I had a stripped out car, it sounded terrible without the rubber boot on it put it on and a lot better.
HTH
Old 13-02-2008, 05:48 PM
155lee
155lee's Avatar
yeah,its really whiney and sounds fucked,im going to tackle it tonight i think!cheers,lee
Old 14-02-2008, 06:46 PM
155lee
155lee's Avatar
think when i take it apart ill not put the quickshift back on,the t5 is notchy enough without it,ill cut down and rethread the original stick.i drove it for 15 miles today and it really pissed me off.
Old 14-02-2008, 09:53 PM
cossie604
cossie604's Avatar
Personaly, i'll love my quickshift. Nice and precise with a race car clicky feel. No doubt i'll be changing my mind when I stripping the box down for new syncros
Old 15-02-2008, 07:33 PM
155lee
155lee's Avatar
drove it again tonight,i loathe its clicky notchy feel and the fact i cant use fifth because its too noisy,it was cool to start with,just like a dump valve is,now its irritating
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
20/20 vision
29-09-2015 09:25 PM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: quickshift grinding on a t5 box
