Help! Can't undo the Rear Hub nut....
Feb 7, 2008 | 03:41 PM
I'm trying to undo the rear n/s hub nut so that I can change the rear suspension arm on my Sapphire Cosworth.
I've got a 41mm socket onto a 2 1/2ft bar even with jumping on the bar is not shifting the nut.
Is there an easier way that is wort trying?
Also, are these threads directional, as I'm trying to undo this nut anti-clockwise?
Help, this rear arm needs to be changed for its MOT!
Feb 7, 2008 | 03:44 PM
nearside is counter-clockwise threaded
turn it the other way - lefty tighty, righty loosey
Feb 7, 2008 | 03:47 PM
as above...shouldn't be that tight either from memory...i'm sure i used mole grips to get mine off
Feb 7, 2008 | 03:49 PM
Feb 7, 2008 | 03:51 PM
Feb 7, 2008 | 04:01 PM
Quote:
Originally Posted by Cowboi
i was going to add that on to my reply
Feb 7, 2008 | 04:07 PM
add the jumping on it and your gonna have a struggle to get it off
Feb 7, 2008 | 04:09 PM
Nick - You are a star
Just done it and managed to loosen the nut.
Feb 7, 2008 | 04:17 PM
little tip for you,if the nut has nicks in the edges in the middle its left hand thread.
Feb 7, 2008 | 04:18 PM
i doubt it,your wheel bearings would colapse if that slack.
Feb 7, 2008 | 04:25 PM
Being rwd, I'd have thought they'd be bastard tight, as opposed to nipped up
Feb 7, 2008 | 04:33 PM
i remember having trouble getting hold of a socket to fit, this was when i replaced my rear beam with a zoo one.....i'm sure i used grips, could be wrong though
Feb 7, 2008 | 04:40 PM
You're used to gay wheel drive now, they have nipped up rears
Feb 7, 2008 | 04:43 PM
Resident Wrestling Legend
Feb 7, 2008 | 04:51 PM
If you tighten the nut before hand it'll help loosen it anyway
Feb 7, 2008 | 05:00 PM
Quote:
Originally Posted by dojj
peice of piss with the correct tool.
Feb 7, 2008 | 05:53 PM
he's got a scafold bar and a spanner by the soudns of it
Feb 7, 2008 | 06:28 PM
Yeah, the correct tool
Feb 7, 2008 | 06:37 PM
not even close!!
Feb 7, 2008 | 10:07 PM
not even close!!
"how do you remove yours "
id use an impact gun myself
Feb 8, 2008 | 11:57 AM
To tighten the car will want to roll forward, to slacken it will roll backwards
Same goes for fronts
unless I am really confused, and thats not hard
Feb 9, 2008 | 03:01 PM
fronts are not left hand thread on either so yes,your confused.
Feb 9, 2008 | 04:16 PM
My 3drs n/s/f hub was left handed.
As far as I can remember the rear hub nut torque setting is sommot like 400nm so dunno how some one managed to undo theirs with molegrips
Feb 11, 2008 | 11:56 AM
My 2wd fronts are on the rush ?
Sierrasideways
Oct 8, 2015 06:37 PM
Si B
Sep 12, 2015 06:49 AM
jc1989rs
Sep 5, 2015 08:09 PM
cossirob
Sep 3, 2015 09:17 PM
