Bare shell respray on Escos?
I know its a big job but does anyone have a rough idea how much a drive in drive out bare shell respray would be on a Escort Cosworth?
Lee
Lee
Originally Posted by MK5RST
already stripped Ł1500 drive in drive out Ł2500 guesstimate
Originally Posted by aurallis
do you mean underneath every thign off car like everything and build it back up or do u mean just a body spray.
it would be serious money mate ure on about making it like concours ive heard of like 5 k just to do the under side all brackets etc and stuff renewd or powder coated etc so i recon it would be big big bucks lol
well it wont be that bad then lol jut a good spray etc should sort that and point out areas that need attention dont need to strip it back to a shell to do that tho.
Would of thought there were people on here that have either had it done or have done it to a customers car.
Im sure you could get little things like that done easy enuf the under bonnet is only inner wings really isnt it and a battry tray could be done for not a lot im sure just a respray with a few added extras lol wont be too bad
I take back the Ł3.500+ and now say Ł7k +
Just to put another slant on it, I am just going though this with one of my cars, car is stripped of glass, trim lights etc. Needed 2 new wings fitting ( Bolt On) some welding to the body and has been stripped of all paint.
Will be given back to be fitted up with doors, bonet, bumpers engine cover sill covers Ect Ł12.500 inc vat and materials
Still got to fit all trim glass myself, Was quoted Ł9k at 1st
also got quoted from Ł3 k to Ł18k
Paint work or body is manly labor and at around Ł45 per hr so dont take long to mount up the ŁŁŁŁŁ
Although doing what aurallis says might be more economical
Originally Posted by Mixja
mate of mine's a painter, he charged someone Ł4k to do a bare metal inside and out, car was already stripped too...
id be hiring a blaster and doin the underneath, floor n engine bay meself then get a proper painter to finish it off...
I wouldnt sand blast a car tbh would rather it was chemically dipped and stripped less harmfull towards panels as car panels are so thin sand blasting puts small imperfections against the metal slightly stripping the metal of its strenght witch is never a good thing also sand is a bugger to get all out of the nooks and crannies
If i was to do it (homer job) not including getting it dipped ide do it for 2k including materials. That would be including plastic primer and flexibilizer additive for plastics etc and inside out obv
Ide imagine from a good bodyshop to do this job you would be looking at approx 7/8k atleast dependant on condition of car and also what colour
look mate i restore fords day in day out and dont think your car will need as much as you think if its an every day car there is no point doing underneith as it wont last the escort is easiest cosworth to do body wise as the parts come off easily id have to see it but i recon it is alot better car than your making out
get the whole underside of your car steam cleaned and then put it in a garage with a heater to dry it then have a proper look underneith
i would charge around Ł2500 to do the outside of the car and inside all shuts as striping the inside and painting it is pointless unless you want money waisted
id strip the top out of the engine bay and do down to the legs as and sort the bat tray
and if it is being used every day the underside needs a coat of wax oil to stop it rusting use clear as black just looks like shults and is a mess
Kinda agree with Jacko on a few things. Also served my time with ford 12 years ago and even then seen some esco's in some nick body wise but must be scottish weather lol.In saying that had an esco's rally car imported from africa that had its fair share of rust aswell
Inside (as Jack pointed out) 9 times out of 10 is a complete waste of time and effort unless its a colour change or on show same as underside but i always do as a customer asks
even if i do think its gonna look hideous
Im looking to paint inside, outside, underneath, etc on Me Esc Cos. I will strip the engine bay down and either paint it myself or pay a mate and do the same with underneath and inside (Cheaper option and not bothered too much how it looks as long as its rust treated and will last). Then I will pay a mate with his bodyshop to paint the outside (Again I will strip)...
Jacko/Snedboy, why do you say painting inside/underneath is a waste of cash? Would it not prevent rust from appearing for a few years atleast (If done properly)?
12.5k for a paint job
This place must have fucking huge windows in it and a really long straight entrance cos by the sound of things they seen you coming a mile off !!!
No as painting inside wont actually stop rust or anything like that. Rust starts from untreated area's exposed to water that iseant waxed properly. Best thing you can spend money on in a bodyshop is getting them to waxoil inside car i.e a,b,c pillers floor,sills behind dash etc etc etc then steam clean underside and do same again especially inside chassis legs etc and once dried a good shutz underneath and job done
IMO ofcoarse
IMO ofcoarse
like my fiesta turbo im doing for myself
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
