Cat 1 Alarm recommendations
I need to have a CAT 1 alarm installed but I'm looking for suggestions. I've had experiencees with Cliffird (good if correctly installed) and Autowatch (basic but good for what it did).
I can have it installed at home in East Yorkshire or Edinburgh, where I work during the week.
So if anyone has suggestions for an alarm or good experience with installers in E. Yorks or Edinburgh, please let me know.
Thanks,
Shanny
Thanks,
Shanny
Toad C5T2, which is 2-1 upgrade, depending on which car you have, failing that as above ai606, the 600 was better but no longer made unfortunately, just make sure you get and keep safe your 4 number code with it, as you will need this to change settings(if you want to).
