GAZ coilovers modifying before fitting?
Old Feb 5, 2008 | 05:18 PM
cossiesmølfDK's Avatar
cossiesmølfDK
Default GAZ coilovers modifying before fitting?
I have ordered a set of GAZ gold coilovers.
The guy i talked to said that you need to modify something on the steering arm ????? and also something in the back where the shocks are at.
Does anyone have some pictures of this and what they have done ???
Hope someone can help
Old Feb 5, 2008 | 07:32 PM
ECOS95's Avatar
ECOS95
I remember Mike R saying that the wheel arch around or near the mount has to be modified to stop the Coil over rubbing the wheel arch. Can't remember what side it was.
Old Feb 5, 2008 | 08:06 PM
ESCYSCOTT's Avatar
ESCYSCOTT
both sides at the back catch the coil springs, best way to do it is fit them and drive the car for a few miles and then you'll see where it catches then you can modify with a hammer ever so slightly.
Old Feb 5, 2008 | 08:12 PM
Kelv's Avatar
Kelv
Almost there!
steering arms etc dont need to be touched.
its as simple as Scott has said, the rear springs just rub ever-so slightly on the rear, and put right in moments.
Old Feb 8, 2008 | 07:37 AM
djcossie's Avatar
djcossie
Default hi ya
u reset the tracking with the steering arms after fitting coil-overs
JoeyBoyden
Jan 4, 2024 02:36 PM
yatta
Sep 1, 2015 11:28 AM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
adam151082
Aug 11, 2015 04:50 PM
