Saffy fuse blowing problem
Old Oct 6, 2003 | 08:02 PM
Mick_2000's Avatar
Mick_2000
Default Saffy fuse blowing problem
My brother has a 1991 sapphire cossie 4x4 and has a problem with the fueling and ingnition, two nights ago the car died whilst driving and wouldn't start again after inspection and a few phone calls to SCS we put the fault down to the crank postion sensor, we changed that today there was still no spark therefore no fuel pump. After a few more phone calls and searching we were told to look at the fuel and ignition relays...now...
Under the dash near the ECU there is 2 yellow relays 1 with a black fuse holder and 1 with a yellow fuse holder...the black fuse holder holds a 15amp fuse, this was blown so we changed this and the car ran for ten mins then the same thing began to happen all over again....then the fuse blew again.
So after all that what does thi fuse do and what will keep making it blow???
Any help greatly recieved as we are clutching at straws here!
CheeRS Michael
Old Oct 6, 2003 | 08:33 PM
RS500/364's Avatar
RS500/364
you tried to change the relay and look for a water leak /damp check the gromets near wear the loom goes though PLUS WHEN A ALARM OR IMMOBILER IS FITTED SOME FIT IT NEAR AND TO THAT RELAY TO CUT THE FUEL CHECK THE WIRE IS NOT SHOWING IT COULD BE SHORTING TO EARTH ANOTHER IT THE ISOLATOR SWITCH IN THE BOOT LOSE WIRE CUZED MINE TO BLOW BEFORE
Old Oct 6, 2003 | 09:27 PM
Mick_2000's Avatar
Mick_2000
cheers for that
Give a me few things to be going at- If anyone else has any other ideas then please let me know
CheeRS Michael
DAZZER
Sep 30, 2015 08:43 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
