How lean can u go!
Old Feb 3, 2008 | 10:17 PM
mudgey's Avatar
mudgey
Default How lean can u go!
Those out there with carbs or infact fuel injection for that matter, how lean can you push a petrol engine before you get meltdown! What areas suffer the most from ultra lean running?
I'm thinkin about this modified mk4 i'm plannin on doin, it wud b less hassle if i built a rev happy 1600cvh for it on DCOE 40's but i'm also concerned about economy!
I read sumwhere that sumone built a weber cvh with a big valve ported head etc and ran it at 40mpg or summit during the fuel crisis! that sounds good to me!
Can you run a cooler thermostat? That would let you run leaner right? But ive heard that engines run more efficient the hotter they are!
Old Feb 4, 2008 | 05:43 AM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
Default Re: How lean can u go!
Doesnt sound realistic.
Old Feb 4, 2008 | 08:19 AM
JesseT's Avatar
JesseT
You can go very lean on cruise, even to ~20:1 afr with a good combustion chamber (not cvh). It's not the most efficient way though. On a CVH I run ~15.5:1 on cruise.
The first things to suffer from running too lean on high loads would probably be exhaust valves and plugs.
Oranoco
41
Feb 11, 2016 01:28 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
kosienutter
31
Aug 22, 2015 09:55 AM
s2_rsturbo
Dec 18, 2004 12:13 PM
