rs turbo engine into a mk5 escort
as far as i aware the engine goes strait in! the engine in my car at the moment is a 1.4 carb'ed cvh will my 1.6 rs turbo engine loom plug strait into the car or is their a bit more to it?
The engine is no problem,straight fit.wireing on the other hand is not.The loom for a mk4 turbo is soooooo long its unbaleivable,it goes round the engine bay in a circle for sum reason.its not hard to do but the easiest way is to seperate the engine loom,shorten it and wire it in seperately job done.
I did something similar on my MK5 carb cvh. It's now running an OFAB turbo engine. The loom off a FRST was quite easy to adapt to my engine bay. Just needed to extend a few wires. I found it reasonably straight forward to mount the fuel injection and fuel pump relays near the battery.
Another pain in the ar$e you'll have to overcome is fuel. I changed my tank for one off a MK5 XR3i and raided the engine bay fuel piping from an EFI 90 spec MK4 XR3i, bought a new fuel filter and plumbed it in.
The place where the wiring links up to your existing car loom is behind the battery, just a simple multiplug. The only things you'll need to identify are oil pressure, rev. counter and ignition live etc.
Find full info on www.rsbible.co.uk
Good luck m8
Good luck m8
