boost control
Old Feb 3, 2008 | 09:17 PM
leecavturbo's Avatar
leecavturbo
Default boost control
where should the reference for actuator control
come from?
i.e from near the throttle / inlet plenum or
from as close to the turbo outlet as poss?
i've always had unstable boost and as my boost
is starting to get higher the unstable boost is more
prominent and annoying.
Old Feb 3, 2008 | 10:14 PM
mechanic28's Avatar
mechanic28
on your cavelier think it is done by the pressure in the inlet manifold
Old Feb 3, 2008 | 10:39 PM
leecavturbo
my setup is vastly different from std,
not using vx turbo or ecu or map sensor
or boost control all aftermarket stuff
Old Feb 3, 2008 | 11:07 PM
mechanic28's Avatar
mechanic28
oh in that case can u not run it off a amel valve which is linked to the actuator and compreesor housing and wired into the ecu?
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
