escort cossie engine conversion help
Old Feb 3, 2008 | 09:11 PM
liamford's Avatar
liamford
Default escort cossie engine conversion help
i have an st turbo and im going to change to large turbo, hopefully soon, i kno i have to chane the ecu system to an omex 600 or autotronic or something, but before i have it fitted and mapped i have to fit everythiing else. but i dont kno what too get and i wanna run around 400bhp,
current spec (engine rebuilt 4k ago harvey gibbs)
-low comps machined valve cut outs
-mild port and polish head
-rs 500 intercooler
-ggr 305 bhp kit.
im going to get a tubular manifold, but i dont kno what turbo, cams or injectors too get, any advice would be greatfull guys !!!
Old Feb 3, 2008 | 09:15 PM
Kelv's Avatar
Kelv
Almost there!
id say firstly you dont need to run Autronic or Omex.
you could easily run it on L8 or P8 with no drama's. in fact id personally run it on L8 if i were in your shoes.
why are you going for a tubular manifold?
if your only after 400bhp then a T34 would possibly do you good, or maybe even go for a UT T38!
Old Feb 4, 2008 | 12:28 AM
liamford's Avatar
liamford
l8 is the older ecu's right? im not too clued up on that stuff thats why i just thought it would be easier to get a new system installed? whats a ut t38 turbo then??
Old Feb 4, 2008 | 06:34 AM
- Sim -'s Avatar
- Sim -
UT 38 =
hybrid turbo build from a T34 turbo.
but a t34 stage 3 with 360° bearings and cut back blades will suit up to 430 bhp normally, with low lag.
also need an big turbo manifold
you can go different ways:
first:
l8 ecu/P8 ecu with software (several dealers carry that) for that (grey injectors) incl. Weber Marelli loom engine sided, then you ll need a big turbo throttle body also, because the small turbo manifold won't work with that ecu (without modification to the TB)
second:
Go for an aftermarket ecu like Omex, Autronics, DTA or so...
get a bigger turbo, get everything mapped...
Old Feb 4, 2008 | 02:51 PM
liamford's Avatar
liamford
i think i will go the omex or autotronic way i think guys when the time comes? can you still run greys with those types of ecu? or go for something like seimens?
any ideas on cams guys?
Old Feb 4, 2008 | 06:26 PM
GUZZLER's Avatar
GUZZLER
my car runs an Omex 600 ecu, TT T38 turbo & siemens high impedence 650cc injectors, it was pulling 435bhp at 30 psi, it now has a different coil setup, bigger plug gaps, & 32psi if i want it.
Old Feb 4, 2008 | 09:40 PM
liamford's Avatar
liamford
nice!! yeah thats the sort of results i want,
where did you get you omex 600 fitted and mapped too? also how much lol
Old Feb 6, 2008 | 02:24 PM
Gordon1's Avatar
Gordon1
do you want to keep the std loom or are you wanting a new engine loom
Old Feb 10, 2008 | 07:23 PM
mk1 chris's Avatar
mk1 chris
Hi, we fitted it at Torque of the Devil, Matt got a special price as he was a mate, (but is now a serious threat ) but to supply fit and map a similar set up would cost Ł1600 for the omex 600 system or Ł1800 for the omex 700 full spec system, both plus the dreaded VAT im afraid.
chris
Old Feb 10, 2008 | 07:56 PM
Mark V8's Avatar
Mark V8
I'm sure Stu@Motorsport developments can do this conversion with the stock ECU.
Mark
Old Feb 11, 2008 | 09:52 AM
GUZZLER's Avatar
GUZZLER
liamford my car has been getting some bits altered on the map recently, in the near future i will have some good options for small turbo escos owners.
Old Feb 11, 2008 | 11:37 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Mark
BANG ON!!
you dont even need to change the ECU stu can map this no probs give him a call before you go shelling out for ECU's and looms ect
Old Feb 12, 2008 | 09:32 PM
Robski's Avatar
Robski
has this conversion been fine tuned yet? I'm sure its still in the development stage?
Billy_RS
16
Oct 11, 2025 09:41 PM
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
stickyslick
14
Aug 10, 2015 06:27 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
