Cosworth Wiring Project - Help needed
Old Feb 3, 2008 | 08:02 PM
ickey818's Avatar
ickey818
Default Cosworth Wiring Project - Help needed
I need some help with a little wiring project I want to do on my 1993 Sapphire Cosworth.
I have decided to replace the engine wiring loom but want to build my own loom rather than buy one off the shelf. Before I get started I have a couple of questions which I hope someone can help me with.
Can anyone tell me what gauge of wire is used in the originally Cosworth engine loom or what ampage wire I should be using? Is there any tools available to measure the wire gauge in my current loom?
Also can anyone tell me where you can buy the small yellow labels which go on the loom to identify what each plug is for? I have seen these on some aftermarket looms but can't find them on the web.
Thanks
Old Feb 4, 2008 | 02:14 AM
velocity's Avatar
velocity
try these lads, they have everything for the electric end of things, look under cable sleeving and then cable markers i think they might be what your looking for, plus they have all the different end fittings and connectors.
http://www.vehicle-wiring-products.e...e/homepage.php
JoeyBoyden
Jan 4, 2024 02:36 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
