Removing the camshaft??
Old Feb 3, 2008 | 01:56 PM
seanex's Avatar
seanex
Default Removing the camshaft??
Hi,
Right I am removing the cam due to it being worn, problem is I cant get the pulley off so i can get the cam out. Everything i seem to try just turns the cam
Any ideas or how have you taken yours off
cheers
Old Feb 3, 2008 | 02:01 PM
picky775's Avatar
picky775
tap it lightly with a piece of wood,if your standin on drivers side tap it toward you,it will cum off eventualy.spray wd40 on it aswell
Old Feb 3, 2008 | 02:06 PM
seanex's Avatar
seanex
no i mean i cant undo the bolt on the pulley, how do i lock the dizzy end of the cam as i havent got the removal tool, you are fast becoming my saviour mate
Old Feb 3, 2008 | 02:07 PM
picky775's Avatar
picky775
put a lond screw driver through cam pulley and jam it underneath the head.
Old Feb 3, 2008 | 02:08 PM
seanex's Avatar
seanex
do i need to loosen the allan key bolts ontop of the cam housing??I need to take the followers out as well
Old Feb 3, 2008 | 02:10 PM
seanex's Avatar
seanex
is it a standard thread i.e left turn for off
Old Feb 3, 2008 | 02:11 PM
picky775's Avatar
picky775
undo all 8 rocker arms,keepin them in correct order,there is a locking plate at pulley end when you get pulley off undo the two 10mm bolts and lift plate out then push cam out.refitting just reverse what you have done.
Old Feb 3, 2008 | 02:12 PM
picky775's Avatar
picky775
yes left is undo
Old Feb 3, 2008 | 02:13 PM
seanex's Avatar
seanex
wont the valve springs cause them to fly every where??
Old Feb 3, 2008 | 02:14 PM
picky775's Avatar
picky775
nope as the valve springs are locked on by collets.
Old Feb 3, 2008 | 02:16 PM
picky775's Avatar
picky775
the bolts i said are 10mm i think there actualy 8mm.
seanex's Avatar
seanex
quality so just take all rocker arms off, stored them in order. Undo the pulley via brute force, take the plate out and push the cam out,, if thats right im off in the cold again
Old Feb 3, 2008 | 02:19 PM
picky775's Avatar
picky775
yeh but dont forget to take followers out aswell as you wont move the cam otherwise,you may need a pair of pliers to grab them as sumtimes they stick a bit.
Old Feb 3, 2008 | 02:22 PM
picky775's Avatar
picky775
dont forget to take the woodruff key out the old cam as you will need it to fit to your new one,its a half moon shape piece of metal on pulley end.
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Orion_Gav
Sep 29, 2015 04:50 PM
