engine setup required
Old Feb 2, 2008 | 05:44 PM
crazy kid 1's Avatar
crazy kid 1
Default engine setup required
hello all ive owned my escos for over 2 years now and fancy having it setup as its never seen a tuner before,the car is always regulary serviced and has had a rebuild about 2000 miles ago with new 0.5mm low comp pistons all new shells reground crank and high pressure pump,head as also been skimmed and slightl ported but still not got round to upgrading camshafts as im not sure what to go for? also running greens and standard t34 but also looking to upgrade. can any1 tell me a good engine tuner to use as i live in kent and not sure who to use
Old Feb 2, 2008 | 05:57 PM
GUZZLER's Avatar
GUZZLER
the standard cams will be fine, if you want a rolling road tune i could organise that at Power Engineering Tuning, drop me a pm if your interested.
as for injectors & turbo, it might be best to get it set up as it is for now, enjoy the power for a while then look at upping the power some more when you get used to it!!
when you decide to upgrade you could go for a T38 turbo or a GT series one, for injectors you could use greys of siemens, i would opt for the siemens.
3drRich
Sep 13, 2015 07:32 PM
gchristophi
Aug 31, 2015 10:36 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
yawiejon
15
Aug 9, 2015 06:36 PM
