odd sound.
Old Jan 29, 2008 | 10:08 PM
lukemakepeace's Avatar
lukemakepeace
Default odd sound.
i think its either clutch or gear box.
basically when at idle its fine, revving in nutral fine.
but when i drive it as the speed/revs increase it whines, if i dip the clutch it stopps and if i put it in nutral it stops but when in gear it whines and gets higher and louder as speed increases.
Old Jan 30, 2008 | 03:46 PM
picky775's Avatar
picky775
Sounds like diff bearings are fooked
Old Jan 30, 2008 | 03:47 PM
T3ORA's Avatar
T3ORA
I SECOND THAT
Old Jan 30, 2008 | 04:59 PM
picky775's Avatar
picky775
The reason when you de clutch it or put it in neutral theres no stress on the diff bearings until you put it under load,i had the same thing a few months back i just got a new box.
Indyrs
Dec 4, 2022 12:39 PM
timsrs
Nov 13, 2018 11:48 AM
155lee
Oct 24, 2015 11:11 AM
Fudgey
Sep 17, 2015 01:06 PM
