Idle adjustment on a series 2 RST
Old Jan 28, 2008 | 09:45 AM
Cerby's Avatar
Cerby
Default Idle adjustment on a series 2 RST
I want to adjust my idle speed when ticking over on my S2, Is it in easy job. When warm it seems to be ticking over at 1400 rpm, I want to take it down to about 1000 if poss.
Many thanks
Nick
Old Jan 28, 2008 | 10:18 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
There's a small screw under the metering unit iirc
Old Jan 28, 2008 | 12:03 PM
diesel's Avatar
diesel
if it's mfi like mine it's by the throttle position sensor a brass screw with a spring on it. im not sure on the efi
Old Jan 28, 2008 | 12:08 PM
Daveysaff's Avatar
Daveysaff
Dead right, i was thinking of the mixture screw
Old Jan 28, 2008 | 12:52 PM
Cerby's Avatar
Cerby
many thanks, will give it a go later
Old Jan 28, 2008 | 04:12 PM
Alvyn's Avatar
Alvyn
the screw at the bottom of the throttle body screws inwards to reduce the revs!
Old Jan 28, 2008 | 04:14 PM
S2Steve's Avatar
S2Steve
What about efi?
Old Jan 28, 2008 | 09:10 PM
picky775's Avatar
picky775
The efi idle screw is in front of the iscv on throttle body,screw in for lowering,out for raising idle speed
A.t.p
Oct 23, 2015 07:54 PM
AJC
Oct 8, 2015 11:09 AM
Fezman1
Oct 2, 2015 01:22 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
