Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS2000 4X4 AND MONDEO 4X4 PROPSHAFT
Old Jan 27, 2008 | 10:11 PM
steelcabby's Avatar
steelcabby
Default RS2000 4X4 AND MONDEO 4X4 PROPSHAFT
Hey all, is the MONDEO 4x4 propshaft the same length as the RS2000 4x4 propshaft?? or will i have to shorten the RS2000 4x4 propshaft?
i know the ends are the same where they joint the rear diff and transfer box.
i am putting a RS2000 4x4 convertion on me mk5b and i am using a mondeo gearbox and transfer box. i was told the transfer box on a mondeo is bigger than the RS2000 4x4. so i just wondered if the props where the same size. if not, then who does prop shortening and balancing etc??
Old Jan 28, 2008 | 05:52 PM
Mark_'s Avatar
Mark_
not sure about the above but you will need to do somthing about the spare wheel well on your car if its not a 4x4 as the 4x4 well isnt as deep so there is room for the diff.
Old Jan 28, 2008 | 07:13 PM
steelcabby's Avatar
steelcabby
Spare wheel well is going mate, don't want it there anyway
Old Jan 28, 2008 | 07:22 PM
Mark_'s Avatar
Mark_
ok mate just thought i mention it
Old Jan 28, 2008 | 07:41 PM
steelcabby's Avatar
steelcabby
yeah thats ok, thanks for that. any bit of info is good info mate
Old Sep 25, 2009 | 09:42 PM
AndyRsVan's Avatar
AndyRsVan
New to you
Hi, The propshaft off the mondeo is slightly longer, 1 thing youll have to check is the ratio in the front diff off the mondeo and the rear rs2 4x4 diff as the rs2000 4x4's have 3 different ratio set ups thats where a lot of people fcuk up, when their gearbox goes in rs2 4x4 they just stick any rs2 4x4 gearbox on without checking ratio ( like i did twice and killed 2 transfer boxes ) then you end up with a shagged transfer box
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
The Enigma
Sep 29, 2015 10:31 AM
