cooling fan
Old Jan 26, 2008 | 03:06 PM
runty176's Avatar
runty176
Default cooling fan
not sure if my t34 escos fan is running at full power .
are they a 2 stage system ? (no air con) has any one got a wiring diagram please .
they come on stage 1 but i havent heard them going flat out .
i notice the termo switch has 4 wires so i am thinking there is a fault on stage 2 ?
Old Jan 26, 2008 | 05:25 PM
fish99's Avatar
fish99
They are 2 stage fans.... What I would do is bridge the terminal at the plug to see if they come on. Bridge 2 big terminals then bridge the 2 small terminals.
Obviously if you get two fan speeds when you bridge then its a problem with the fan switch.
Old Jan 28, 2008 | 08:29 AM
Dave Henshall's Avatar
Dave Henshall
i had a problem with mine, the pins on the rad switch had corroded off in the multiplug leaving me with no HI speed fans, i swapped the switch for a 2wd one and grafted some tails onto the 2 connections , then common up the 2 black and the 2 black/brown wires which makes the fans come on at high speed at the lower setting of the 2wd swicth, when running more boost it helpskeep the under bonet temps down a bit
some pics....
Old Jan 29, 2008 | 06:30 PM
runty176's Avatar
runty176
found the switch to be faulty so did what dave did
who needs stage 1 anyway
flat out or nothing is the only way
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
