Can an Omex Limiter damage your engine?
Old Jan 26, 2008 | 01:08 PM
S2Steve's Avatar
S2Steve
Default Can an Omex Limiter damage your engine?
Anyone? Fitted one yesterday and already been warned by a few people. I figured its only unburnt fuel getting chucked out on the limit occasionally, so it cant be tooo bad?
Old Jan 27, 2008 | 10:35 AM
S2Steve's Avatar
S2Steve
Old Jan 27, 2008 | 10:47 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
its more dangerous than it not happening, but less dangerous than over revving and killing your engine, and in reality will do fuck all damage.
cossies, 205gtis, etc etc etc all have ign cut limiters like the omex is as standard, can bounce off em all day, it will do fuck all bad thats related to the unburnt fuel, unless your mega unlucky.
Old Jan 27, 2008 | 10:52 AM
S2Steve's Avatar
S2Steve
Cool. Presumably hard cut is more dangerous than soft cut? But hard cut is the fun setting
Old Jan 27, 2008 | 03:56 PM
july1's Avatar
july1
It's not good if you still have the catalyst, as unburned fuel will damage it.
If you don't you may still damage the exhaust valves and seats as well as the turbine with back firing.
But supercharged engines don't needs to be pushed to the limiter so it should not be a real problem
Old Jan 27, 2008 | 06:28 PM
S2Steve's Avatar
S2Steve
But the limit is only at 3.5k at the moment as i'm running the new head and cam in. Its a straight through system without a cat too if that helps.
Old Jan 27, 2008 | 07:14 PM
july1's Avatar
july1
ok, I see.
well just try to avoid to hit it and you'll be fine
Old Jan 27, 2008 | 07:31 PM
S2Steve's Avatar
S2Steve
But its so much fun hitting it
Old Jan 27, 2008 | 07:55 PM
july1's Avatar
july1
I know, I've got one too but from another company using Omex technology (I forgot the name) I choose this one because he has a WOT gear change limiter feature.
But with the MT75 I don't want to use it
I'll get a R&D soon or late
Old Jan 27, 2008 | 08:04 PM
S2Steve's Avatar
S2Steve
R&D?
Old Jan 27, 2008 | 08:10 PM
july1's Avatar
july1
That's the name of the gearbox manufacturer that supplied the Escort works cars. They are top of the range
Old Jan 27, 2008 | 08:22 PM
S2Steve's Avatar
S2Steve
Nice
jay030787
Sep 18, 2015 07:34 PM
Tim Wharton
Aug 30, 2015 05:46 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
