Do i adjust timing or feuling 4 nos?
Old Jan 24, 2008 | 07:57 PM
m_nettleship's Avatar
m_nettleship
Default Do i adjust timing or feuling 4 nos?
St220.
if i run nos,, do i need to adjust anything else????
Thanks.
Old Jan 24, 2008 | 07:58 PM
Gordon1's Avatar
Gordon1
how much you running and what kit
Old Jan 24, 2008 | 07:59 PM
m_nettleship
75bhp jets on progressive controller, wet kit. with bottle warmer, single point.
Old Jan 24, 2008 | 08:00 PM
Fagin's Avatar
Fagin
If your having to ask I suggest you discuss with a tuner tbh.
Old Jan 24, 2008 | 08:02 PM
m_nettleship
i thought there were tuners on here
Old Jan 24, 2008 | 08:05 PM
mechanic28's Avatar
mechanic28
i would say yes
Old Jan 24, 2008 | 08:08 PM
Gordon1's Avatar
Gordon1
you will need to get the fueling and knock checked out
is it a wizard kit
Old Jan 24, 2008 | 08:18 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
shouldnt need to do stuff, just checked.
as long as the fuel and gas jets are correct that is.
checking is vital tho, as might det if you unlucky, and plugs or something also may not be up to it
Old Jan 24, 2008 | 08:26 PM
abdr500's Avatar
abdr500
both ig and fuel needs adjusting other wise best way to blow it up
leecavturbo's Avatar
leecavturbo
you need to run a 25bhp jet test to determin
your nos/fuel ratio.
Old Jan 24, 2008 | 08:39 PM
badnews's Avatar
badnews
not just bolt on lad but not to much bother to set up just need to check it's not leaning off at top end.
Old Jan 24, 2008 | 08:45 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Are you running a Wide Open Throttle Sensor and a window switch? Or is that part of your controller?
Might be worth running a cooler plug as well - depends what your tuner thinks when you get a det/fuelling check done.
Old Jan 26, 2008 | 12:29 AM
m_nettleship
its on a progressive controller,, but i will get the spec of it and post it.. Thanks 4 the info. Guys
Old Jan 26, 2008 | 11:29 PM
Big Will_'s Avatar
Big Will_
To give you an idea - this is the Nitrous control map in my AEM ECU:
Old Jan 26, 2008 | 11:32 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
At that level on similar engines, ive found the cooling effect of the nitrous is enough to offset the higher VE achieved, and typically ignition retard isnt needed.
If you need to adjust your fuelling map, you have done something wrong with the nitrous instalation.
Old Jan 27, 2008 | 11:45 AM
m_nettleship
intresting,,,, i no it has a bottle warmer lol,,, I will get the full spec of the kit,, its goin on a mondeo st220,, witch has a level 3 tune by dreamscience,,, maybe ignition will want backing off,, to prevent nocking etc ,, wat you think guys!!!!!!!!!!!!!1
Old Jan 27, 2008 | 11:54 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
like said mate, you wont know till you test it, but typically, not really.
exactly.
been some slightly wierd/gay comments so far
Old Jan 27, 2008 | 12:42 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
My ignition map is not changed in anyway even with a 240bhp shot.
Mark checks the fueling & the fuel jet is changed to get it correct.
For Topspeed runs its checked everytime on the road its fine.
Old Jan 27, 2008 | 04:14 PM
m_nettleship
madman and stav, wat am i listening 4 knocking and pinkin??
and the moment i get slight pinking wen setting off etc,, but not up the revs,, should i load stock program or a less tune,, i have 3 tunes on the program,, moment its running tune no 3.
Old Jan 27, 2008 | 04:32 PM
Chip's Avatar
Chip
Yes, use the stock program, at the moment you have advanced ignition, which is a bad idea on gas.
Old Jan 27, 2008 | 05:03 PM
m_nettleship
chip,, wats the deal with dreamscience unites,, is it just advanced ignition all the way through?
Old Jan 27, 2008 | 10:28 PM
Chip's Avatar
Chip
Ive not seen the maps, but I would imagine so mate.
Old Jan 28, 2008 | 11:57 PM
m_nettleship
Its a wet nos sytem i found out today.
Old Jan 29, 2008 | 12:00 AM
MK5RST's Avatar
MK5RST
sorry, just had to post it.......
http://video.google.co.uk/videoplay?...arch&plindex=0
Old Jan 29, 2008 | 12:02 AM
Chip's Avatar
Chip
Post a picture of the solenoids, or at least a description please mate.
As I dont really see that it can be a "nos" system if its progressive, as their solenoids are absolute wank and cant handle being used progressively.
Old Feb 2, 2008 | 12:31 PM
m_nettleship
Nos is now fitted, it has a progressive controller with a 11 pound bottle, 2 solanoids red and blue 1 feul 1 nos.
its on 40bhp jets , but need the bottle warmer wired up,, as the pressure is a litttle low,, bottle to cold,,
Old Feb 2, 2008 | 02:08 PM
Badman38's Avatar
Badman38
thats a wizard of nos kit you should'nt need to touch the timing the kit will be goog to go.
sean
Old Feb 3, 2008 | 07:26 AM
m_nettleship
i no,, visited them yesterday,, need bottle warming up.
jessie_rs
11
Jun 3, 2019 04:57 PM
YODI
Aug 30, 2015 01:12 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Graham S1
Technical essay Archives
Aug 24, 2015 03:58 PM
155lee
14
Aug 22, 2015 12:15 PM
