L8 ecu in 2wd cossie?
Old Jan 24, 2008 | 12:56 PM
tommeke's Avatar
tommeke
Default L8 ecu in 2wd cossie?
hello,
Is it possible to put a L8 ecu in a 2wd sierra cosworth 3dr?
now the car have a L6 stage 3 ecu bij MSD
but I want to put the new MSD software in with closed loop, anti lag and maybe launch control...
Is it posible to put the L8 ecu on the engine loom of a 2wd?
can i fit somewhere the lamba sensor on the engine loom or do I have o search a engine loom of a 4x4 sierra?
sorry about my bad english
cheeRS
Old Jan 24, 2008 | 01:08 PM
rsnissan's Avatar
rsnissan
Yes you can
you need a 4x4 TPS and will need to swap the two outer wires round
you can add the lambda control with the existing loom (run a seperate mini loom from the ECU)
Old Jan 24, 2008 | 02:44 PM
capri280's Avatar
capri280
yes as stated
you can fit an l8 ecu into a 2wd
as stated you need a tff09 sensor to change and swap wires around
i have one fitted to my 2wd installed bt msd and running closed loop
Old Jan 24, 2008 | 02:52 PM
rsnissan's Avatar
rsnissan
the sensor you need is PF09 not ttf09
Old Jan 24, 2008 | 03:07 PM
capri280's Avatar
capri280
sorry i miss typed it
well spotted batman
Old Jan 25, 2008 | 08:21 AM
Yes you can, but if going this expensive way, to get a few more features you may kick yourself that you did not go aftermarket ecu, as it works out cheaper for a LOT more features, some can use any sensor type/rating as well, and are adjustable sensor inputs too, as well as direct coilpack drive Al/LC/TC/ in gear adjustable booste etc, triple map etc etc etc etc.
Old Jan 25, 2008 | 09:47 AM
tommeke's Avatar
tommeke
where can I find this type of sensor?
and how difficuld is it to connect it?
who's the best man to contact? stu @ MSD?
Old Jan 25, 2008 | 02:39 PM
rsnissan's Avatar
rsnissan
second hand of of any 4x4 cosworth (see if a car is being broken in the parts for sale section)
its is very easy,its is just screwed onto the the throttle body and there is a multi plug (the one you have to swap the wires round on)
I'd get one second hand, you can get the lambds sensor itself from stu though
Old Jan 26, 2008 | 09:37 AM
tommeke's Avatar
tommeke
thx for your advice mate
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
RSmark84
Sep 13, 2015 01:29 PM
jc1989rs
Sep 5, 2015 08:09 PM
