Transit Connect - speed limiters?
Old Jan 23, 2008 | 06:18 PM
fraser9764's Avatar
fraser9764
Default Transit Connect - speed limiters?
I'm sure i read something on here about transit connects been speed limited but i cant find it, does anyone know much about them? i am looking at getting a tdci 90ps low roof model, last owned by something fleet services in sale.
also what are these like for towing? hoping to tow a 205 on a twin axle trailer?
thanks in advance
Old Jan 23, 2008 | 06:20 PM
C4llyT's Avatar
C4llyT
I know all 3.5 tonne and above are having them, connect is small one isn't it?
Old Jan 23, 2008 | 06:53 PM
snoopaloopa's Avatar
snoopaloopa
yeah the connect is the small one, and my 90/350 is restricted to 90mph apparently not that i've ever managed to get it there as its got the option towing diff fitted
Old Jan 23, 2008 | 08:09 PM
fraser9764's Avatar
fraser9764
Old Jan 23, 2008 | 08:10 PM
DazC's Avatar
DazC
Vosa regulations regarding speed limiters only apply to vans bigger than 3.5 tonnes. Bellow that do not need a limiter.
The train weight of a Connect might not be sufficient to tow a car. You need to check your train weight and work out how much your car, trailer and van will weigh when fully loaded. If it exceeds the train weight then you will be illegal if you tow with it.
Old Jan 23, 2008 | 08:21 PM
fraser9764's Avatar
fraser9764
it would be close, what does an average car trailer weigh? and just out of interest, what sort of penalty are you looking at if you are found to be slightly over?
Old Jan 23, 2008 | 08:25 PM
fraser9764's Avatar
fraser9764
looking at the vaux combo, it says GVW 1995, GTW 2815 but max braked towing weight 1000??
http://www.nationwidevehiclecontract...-Technical.htm
Old Jan 23, 2008 | 08:40 PM
MrMPuk's Avatar
MrMPuk
All Ford vans from the factory are limited to 100mph although the speedo will always read more. There was an option of other set limits like 72 which can be removed by a dealer but the 100 is set and cannot be removed by a dealer.
As for towing a car, no hope! Even the smaller Transits can't do that legally.
DazC's Avatar
DazC
Car trailers are around 700kg ish empty.
That braked towing weight just means you can tow a ton without ripping the brake discs apart every time you brake. Any more and you're beyond the design weight of the vehicle and illegal.
With the combo, the combined total must not exceed 2815kg including you sat in it with any equipment you decide to carry.
Slightly over and they will make you remove stuff or stop you from continuing on your journey. More than 300 kg over then they will spank you.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
SMILER258
Sep 28, 2015 09:04 AM
