tyre size on rear of saff???
hi..
whats the widest tyre that will fit on he rear of a saff with comp 18s.
was thinking of toyo r888.. its got konis with bayjo springs so not real low.. .
thanks..
thanks..
thanks for the help.. its 2wd and im just hoping to make the car grip in the lower gears really . from what i can find the toyo r888 sizes seem to look wider than other brands of the same size..
i have read about the adjustable rear beams and how good they are but others have said that they are a bit ott for a mainly road car..
the car is not as bad for grip as some ive seen but as its not got very good tyres on at the minute it must be an improvement by fitting some good ones..
thanks..
thanks..
I run 8" wide on mine with 235 tyres at the mo !
Have rolled the arches but before I run the car so don't know if it would of rubbed or not !
Also try some shims off Mikey Rainbird, a cheap mod to help the dodgy cosworth rear beam if you dont wanna spend a g !
jb
Have rolled the arches but before I run the car so don't know if it would of rubbed or not !Also try some shims off Mikey Rainbird, a cheap mod to help the dodgy cosworth rear beam if you dont wanna spend a g !
jb
turbotrev
14
Sep 6, 2015 10:27 AM
Marc sierra
12
Aug 30, 2015 10:38 AM
borboyous
Aug 22, 2015 11:17 AM
