erst fuel pump rewire
Old Jan 22, 2008 | 12:46 PM
jonesymk2's Avatar
jonesymk2
Default erst fuel pump rewire
anybody have any rough wiring diagrams atall please,should i run an earth for the pump straight to the battery,would a 20amp fuse be ok,should i put the immobiliser before or after the relay,where do the other wires go from the relay
Old Jan 22, 2008 | 12:53 PM
coco16i's Avatar
coco16i
Wouldn't have thought the earth wire for the pump needs to go all the way to the battery, just a good solid earthing point near the pump will do.
20A fuse should be fine for carrying that kind of load.
As for the relay wires,
30 = Battery positive
85 = Earth
86 = Switched Live
87 = Output to consumer
Old Jan 22, 2008 | 01:39 PM
jonesymk2's Avatar
jonesymk2
which wire would be best to put the immobiliser onto,would it be ok on the battery wire or should i put it onto the switched live from the ecu,forgot to say its efi sorry so dont know if this makes any difference atall
Old Jan 22, 2008 | 01:46 PM
jonesymk2's Avatar
jonesymk2
also the earth to the relay would that be ok to run to the battery or just try get a decent earth near to the relay
Old Jan 22, 2008 | 02:00 PM
coco16i's Avatar
coco16i
The wire for the immobiliser i would say would be best put onto the live wire feeding the relay so it cuts the power at the first available source, ie the relay and not the pump.
The earth for the realy wont need to go all the way to the battery and will be fine on a suitable bolt or screw hole near the relay, i usually run the earth wire from terminal 85 on the relay and earth if onto the bolt or screw i use to secure the relay onto the body.
Old Jan 22, 2008 | 02:21 PM
jonesymk2's Avatar
jonesymk2
would it be best to use a new relay or could i use the original,if a new item is the best choice how do i know what relay i need when i go to buy it
Old Jan 22, 2008 | 02:26 PM
coco16i's Avatar
coco16i
Your original relay will be fine to use mate.
Old Jan 22, 2008 | 02:31 PM
jonesymk2's Avatar
jonesymk2
ok cheers for that much appreciated
Old Jan 22, 2008 | 02:33 PM
coco16i's Avatar
coco16i
No prob mate.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
