Pectel SQ6 ECU ## Sold##
I have a Pectel SQ6 ECU for sale (never used), it has no loom but it has the AMP connector and a box of connector pins so you can make or adapt a loom for it. It also comes with its DescPro CD.
Project changed before it got fitted?
£3000 of kit will let it go for £2200
It can be set up for almost any trigger pattern.
It is full engine management I didnt want any extras, if you want traction control you have to buy it as a add on, like wise gearbox selector control.
This is its spec.
http://www.pectel.co.uk/sub_page.cfm...ucts/editID/34
I was going to buy a Gotech Pro-X loom from Jamsport (£100 ish) and re-terminate it with the SQ6 connector.
Simon.
This is its spec.
Simon.
cheers,
its the extras that make the price a killer tbh, i need all the extras on the ecu, drive by wire, als, launch, traction etc when you send an ecu to pectel for these to be added they are at full price, if you add them at the time of buying then the price is alot cheaper.
I have been quoted for this ecu from pectel with all the extras, your price is ok if you just need it as a std (if you can call it std
) SQ6.
send it back to pectel for the extras (or pay for the keys to the software) and it then would be more money than buying direct.
no worries
cheers
mark
no worries
cheers
mark
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
