Cabby RSTurbo Update 23/01/08
Well after building my self a 7m x 6m garage i though it was about time i started a new project, plus with the XR2Turbo only having 2 seats it not a very child friendly place
Any way, here are the 2 escorts needed
Cabby
RST
The plan is to RWD Cossie the RST in the future, but 1st i need to sort the cabby out to make room.
The idea is to swap every thing from the RST to the Cabby
I started to stripe down the Cabby on Friday 11th and got to this point on Sunday afternoon
The only rust on the car apart from the bottom of the doors
Thats how it looked after the engine bay had a good clean
And the donar car
Spent a few hours on it since sunday, the engine and box are in alswell as the full RST loom and new Deflex engine mounts and a full set of bushes, Just needs plumbing in, and the brake lines sorted as i took the ABS system off.
Cabby
RST
And the donar car
Originally Posted by Grant Gti
One thing though, Pleeeeeeeeeaaaaaaasssssssssseeeeee sell me a pair of spot light brackets
Just a small up date, Got the car running on Sunday on the XR3i fuel pump, Then realised it had an intank pump
plus the original EFi engine is going in my mate 1.3L so he needs the tank and the wiring. Then whilst taking the tank off i noticed that the Cabby did'nt have a rear anti roll bar and the drums where a lot smaller
. So every thing from the back end of the RST had to be removed and refitted to the Cabby. At the same time all the rear bushes are being replaced. I'll have more pic's towards the end of the week.
Originally Posted by NATH-RSZT
cabby looks clean. should go efi as you have all the bits there, nice garage
TPM961
Jan 15, 2018 10:50 AM
