Crank Sensor
Old Jan 14, 2008 | 06:03 PM
mudgey's Avatar
mudgey
Default Crank Sensor
Hey guys, I'm using a crank sensor from an 1800 CVH along with the toothed crank pulley. How far does this sensor need to sit away from the teeth? I have it set about 3mm away but this is purely a guess.
Regards, Mudgey
Old Jan 15, 2008 | 06:12 AM
Normally around 0.6mm- 1.0mm.
Old Jan 18, 2008 | 06:50 PM
Wardy257's Avatar
Wardy257
As above, test it with a multimeter. With the engine spinning you shoudl see at least 0.5v. The faster it spins, the higher the voltage.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
