if you know anything about fuel pumps please look at this
Old Jan 13, 2008 | 03:45 PM
R5COS's Avatar
R5COS
Default if you know anything about fuel pumps please look at this
while i was cleaning the petrol tank today i noticed that the fuel return pipe has broken away from the top of the fuel pump caseing (see tip of screwdriver in pic 1) now what i need to know is does this caseing come with a new fuel pump, or will i have to get this part from ford ? if so does anyone know the part number or where i can get it.. thanks in advance by the way the pump is a ITP048 if this matters as i think the caseing is standard ford item
Old Jan 13, 2008 | 04:34 PM
JHS's Avatar
JHS
Arent these the same as normal Escorts? If so, it shouldnt be much of a problem to get a new one.
Old Jan 13, 2008 | 04:40 PM
R5COS's Avatar
R5COS
that i dont know mate
Old Jan 13, 2008 | 04:58 PM
july1's Avatar
july1
The tube is just welded by some soldering (tin) maybe you can make a new pipe and braze the level sender braket.
Remain to fine the same pipe diameter..
Old Jan 13, 2008 | 07:08 PM
zetecturbo's Avatar
zetecturbo
well just checked microcat mate and its only available as a complete unit with the fuel pump ,ive the tank out of my escos and ive a tank from an rs2000 could compare them if u like mate
Old Jan 13, 2008 | 07:44 PM
Lighty's Avatar
Lighty
you can not get them from ford any more.. But GGR can still get them..
Old Jan 13, 2008 | 07:54 PM
COS 22's Avatar
COS 22
i think
ggr do a replacement kit for it
Old Jan 14, 2008 | 07:54 AM
R5COS's Avatar
R5COS
cheers guys ill make a few calls today
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
