boost
Old Jan 13, 2008 | 11:22 AM
markseries2's Avatar
markseries2
Default boost
i have a series 2 rs turbo and its nearly standard i have put a scorpion exhaust on and a k&n filter with a -31 actuator i put a boost gauge in to see what boost its running and it says 11 psi and its a standard ecu. just wondering if that boost is safe with the standard ecu with fueling and other things
thanks
Old Jan 13, 2008 | 01:29 PM
mechanic28's Avatar
mechanic28
surprised it dont cut the boost out at that level is it holdihg at 11psi?if so way to much for standard u sure it aint been chipped?
Old Jan 13, 2008 | 01:42 PM
big mac's Avatar
big mac
Was'nt this a stage 1 upgrade on the escort? I would have it checked and set up m8
Old Jan 14, 2008 | 01:16 PM
bonus_boy's Avatar
bonus_boy
it should boost shut off at about 10psi...so if yours is running 11psi it must be holding less unless it has been chipped...
standard is about 6/8psi..
Old Jan 19, 2008 | 04:46 PM
markseries2
its standard as i know becuse it has had one owner from new by an old boy and looked after by ford all its life £9000 worth of recipts on pats and labour
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
