SIERRA SAPPHIRE COSWORTH - NO SPARK OR FUEL PUMP? HELP!
i removed the fuel pump relay and then the fuse while the engine was running, and now i have no spark or fuel pump, i have replaced ECU, still no joy, everything else has been checked, what else could it be?
in the boot well unfer the spare wheel there is a white trip ou button push it and try again
this is activated if the car goes over a sharp bump in the road or if the car tilts
the fuel pump does not prime it self, the crack sensor is ok, i did have a problem with the crack sensor before and the fuel pump still primed it self.
though when the crank sensor went it caused it not to spark, which is happening now, i have no sparking and no fuel pump, but when this happened the car was WORKING FINE, it was running on my drive, i pulled the fuel pump fuse out/relay WHILST the engine was running, it stalled, i put the fuse back in, went to start it, NOTHING. turns over but there is no fuel pump and NO SPARKING???
its soooooo strange?
tried that mate, ripped the all the ALARM/ IMMOIBLISER OUT!
an eletrcian said it was the ECU
today we tried a ECU i got from ebay, NOTHING???
so its got a diff ECU
no alarm
no IMMOBLISER
and it still dont work
no alarm
no IMMOBLISER
it shouldnt be the wiring as the car was only idling when i pulled the fuse out, i dont see how pulling a fuse can make wiring faulty? but then again i dont see how pulling a fuse can bring a car to a exspensive stand still...
I wouldn't count on the second hand ecu working ive had this problem and a mate popped round in his cossy and we swapped ecu,s and hey presto it fired up i would check it against a working ecu
hi there ecu will work even if its out of the holder, i had to fix my friends 4wd cossie that had lost its spark and fuel pump,this ended up being the red wire with a white stripe in the passenger footwell near the realy rail this is the live feed for the ecu it goes into a fuse holder with a 15 amp fuse good luck check live feed to ecu or blown fuse.
i had the same problem last yr and i never found the problem, i took a feed via a relay and switch to coil and this gave power to pump and injector the lot and it started straight away,i tried my ecu on my cousin car and it was working fine replaced crank sensor,phase sensor ampplifer and they were all fine
Have you checked the relay for the engine ecu. This relay is also a yellow one. I had a fault on my cossie 4x4 where it wouldnt start and it was the fuse holder for the fuel pump relay. The connections on the fuse holder were corroded. The electrican cut the fuse holder out and put a new one in. He was on 20mins lookin at my car and he cured it in that time.
kosienutter
31
Aug 22, 2015 09:55 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
