What clutch for a a big power escos
Old Jan 12, 2008 | 05:51 PM
escossie560's Avatar
escossie560
Default What clutch for a a big power escos
I wondering what clutches people were using on big power cossies as i have recently fitted a twin plate ,and toasted it almost straight away
so was looking for options as will so be mapping more boost and dont think a six paddle will hold it. Its a road car ,with some strip action.
Old Jan 12, 2008 | 05:56 PM
Kelv's Avatar
Kelv
Almost there!
AP 6 Paddle and Hydraulic clutch from Reyland.
as recomended by Martin himself and engine is on the plus side of 500bhp
Old Jan 12, 2008 | 05:58 PM
Mark Shead's Avatar
Mark Shead
Twin plates are fine just dont do big launches with them slipping as they cant handle the heat.
Mark
Old Jan 12, 2008 | 05:59 PM
escossie560
have a centre push hydraulic but i will be running 2 bar plus on a gt30 plus gas not sure how well the 6 paddle will hold
Old Jan 13, 2008 | 04:50 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Is it a Reyland centre push kit? I will be running one along with a tilton twin plate, identical set up to martins car , what twin plate did you have?
Old Jan 13, 2008 | 05:45 PM
escossie560
not sure of clutch kit origon , it a quarter master twin plate managed to over heat it launching ,have got to be more brutal and launch with no clutch slip going to f~ck more diffs and drive shafts though.
Old Jan 13, 2008 | 06:05 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Mark
Not true, the twin plate fitted to my car will take repetitive launching and 800ft/lb of torque but has very nice road manners.
Old Jan 13, 2008 | 06:49 PM
escossie560
Mark
well new plates have be ordered with yourself martin , but as mark said and i was told by the main man from quarter master they dont like heat from slipping ,they did show me there carbon clutch but jesus how expensive
Old Jan 13, 2008 | 06:54 PM
NEIL A's Avatar
NEIL A
Was just thinking of putting up a similar post but Kelv's answer covers me
Old Jan 13, 2008 | 07:08 PM
Martin-Hadland
Mark
My clutch is not the same size as yours... Yours uses 7.25" plates mine uses 8.5"... Having said that my previous car used the same clutch as yours and did at least 10 runs back to back at Brunters resulting in a 2.8 0-60 and the clutch didn't fail.
The two clutches for comparison, the larger one is only available from myself..
Old Jan 13, 2008 | 07:10 PM
escossie560
so your going to run a six paddle , got to be honest mine was running 480bhp plus a shot of gas and holding fine but that was only with 1.9bar of boost going up to 2.4 soon and a bigger shot of gas so whated to be sure it would hold
Old Jan 13, 2008 | 07:14 PM
Mark Shead's Avatar
Mark Shead
Mark
It is true, They will not take lots of slip, Launch correctly and you will have no problems with them, Bodge launch's and you will kill them.
Mark
escossie560
martin is nt the plate with the smaller one a race plate ,the rally plates i have seen look like mini 6 paddles
by the way im not doubting your advice was more looking for options
Old Jan 13, 2008 | 07:17 PM
escossie560
Mark
Mark
says it all , did not realise how easy they were to kill until i had a chat with rod at brunters,it was to late by then the plates were cooked ,at least its not a big job taking my gearbox out is now a service job lol
Old Jan 13, 2008 | 07:20 PM
Mark Shead's Avatar
Mark Shead
Mark
Mark
If you can launch correctly they will last, If you get lots of slip then you need to cool them down and dont do it repetedly.
Mark
Old Jan 13, 2008 | 07:28 PM
escossie560
Mark
Mark
Mark
Pretty much what i was told by rod he said he had killed a couple getting used to them
Old Jan 13, 2008 | 07:30 PM
Martin-Hadland
No, the smaller one is a 'rally' type plate. The six paddle version is the AP type.
I only speak from experience but sadly I have only been using these clutches on 4x4's for about 8 years so take what I have said with a pinch of salt
Old Jan 13, 2008 | 07:56 PM
escossie560
as i stated im not in anyway douting your advice as im in no persition to do so ,will be using the twin plate and trying to slip it a little less as i know it was my own fault i over heated it, just do nt like just dumping the clutch as im sick of breaking things
Old Jan 13, 2008 | 08:17 PM
Martin-Hadland
Obviously if you slip the life out of any clutch the end result for the clutch is not going to be good! But if you think that I side step the clutch to get results then consider this.. There is a video if me launching my car time after time at Brunters but on one run I manoeuvre the car to get it ready to launch but stupidly leave it in reverse I launch the car but it only creeps backwards about one foot as I was able to detect the car was travelling in the wrong direction, that alone means I slip the clutch off the line! I suppose it depends on how much slip is used.
yatta
May 21, 2016 10:31 PM
Flateric_2002
Sep 15, 2015 08:41 AM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
