lost keys
Old Jan 12, 2008 | 04:42 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default lost keys
hi
a mate of mine has a m reg ford mondeo 1.8 zetec, and has lost the keys.
hes phoned fords to find out price of getting new keys, and because of the price has decided to scrap the car in stead.
so now to my question and that is im thinking of having the car off of him just for the engine to put in my old anglia 105e. is there any way i can start the engine with out the keys, if so how do i go about it to over ride the transponder
many thanks
mark
Old Jan 12, 2008 | 05:17 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
If you're gonna put the engine in your anglebox, just stick it on mega jolt or something aftermarket for cheap, and you wont have top worry about the PATS
Old Jan 12, 2008 | 07:21 PM
MARKYMARKONE
Daveysaff
thanks for the help, the reason i wanted to get it started was to get it home
mark
Old Jan 12, 2008 | 07:36 PM
project rs's Avatar
project rs
firstly you'll have to break steering lock if a piece of scaf bar is handy or something strong use that as a lever. next you need to take cowlings of and take back part of iggy barrel of and use a screw driver to use as a key, now depending on model, age etc you need to take power to where ever the engine is immobilised so that when you try to start it you'll in effect bypass it probably fuel pump and hey presto should work. we've bypassed a few at work when keys are lost with code in so we normally give reg in to fords and get the right key for locks etc but with no transponder in them for fiver then run a wire from acc on iggy to where ever is immobilised and that works too, pats systems are quite easy to get round.
Old Mar 12, 2008 | 09:33 PM
DIORYY's Avatar
DIORYY
Default 1.6zetec into 1.8zetec
Im putting a 1.8 into my 1.6 zetec the trouble is the colour of the multi plug wires from the injectors are different than in my car the plugs still fit but will the ECU from the 1.8 still work or are they wired different will I need the 1.8 key when its in or is the PATS in the car its self in haynes no mention of pats in ECU.My escort is a 1995 the gti eng is1997 please help?
Old Mar 12, 2008 | 09:45 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
if you getting past the pats pm me and ill tell you where the single wire goes to take it right out
its not summet that shud be put on here
steering lock wise just yank the wheel round 1 way and another til it gives, you'll need 2 peeps and some sweating
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
