sata hard drives compatibility ????
Old Jan 12, 2008 | 05:11 AM
bluescortcossie's Avatar
bluescortcossie
Default sata hard drives compatibility ????
without sounding thick but how do i find out if my PC will run SATA hard drives ???
looking at replacing my small and tired HD's with a couple of 1TB SATA drives but not sure if my computer supports them , and yes i need that much space as i do a lot of video editing and store plenty movies , pics and music
Old Jan 12, 2008 | 07:44 AM
NEO™®©'s Avatar
NEO™®©
does your pc have the plugs to run sata drives? if so then chances are itll be fine lol though you can buy converter leads if you dont already have the sata plugs on ya motherboard
Old Jan 12, 2008 | 08:57 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
.....or you can buy an SATA controller board and run them off that if your motherboard doesnt support them!!!
What motherboard is it?
Old Jan 12, 2008 | 10:55 AM
bluescortcossie
cheers people , i have no idea if i have the plugs and not sure what motherboard i have , how would i find out ?
Old Jan 12, 2008 | 11:17 AM
bluescortcossie
think i just managed to find out what my MB is :
MICRO-STAR INC> MS-6758
does that sound about right ?
Old Jan 12, 2008 | 11:26 AM
Graham S1's Avatar
Graham S1
also, can you run Sata and IDE at the same time? (if you have the plugs on the motherboard that is)
Old Jan 12, 2008 | 02:20 PM
Drewman's Avatar
Drewman
http://www.msicomputer.com/product/p...875P_NEO-FIS2R
That does support SATA drives
Old Jan 12, 2008 | 07:24 PM
bluescortcossie
would that be sata 3.0 gb/s by any chance or does that not make any difference ?
Old Jan 12, 2008 | 09:34 PM
tonyk's Avatar
tonyk
It wont make any difference, if your board can run a sata 2(3gbs) then it will run at that speed, if your board only runs sata 1(1.5gbs) then your board will run the drive at that speed. The are backwards compatible, and obviously a sata 1 drive will not run at sata 2 speeds.
The board posted in the link above is sata 1, dont worry a sata 2 drive will still work at the lower speed.
Old Jan 13, 2008 | 12:51 PM
Alex_86's Avatar
Alex_86
the only disk you could get 300mbs between sata drivers are the 250gb as they usually have 3 plates an can manage that speed
Old Jan 14, 2008 | 11:37 AM
FastFordChris's Avatar
FastFordChris
yes you can.
Old Jan 14, 2008 | 12:21 PM
Graham S1's Avatar
Graham S1
yes you can.
Old Jan 22, 2008 | 04:39 PM
RThomson's Avatar
RThomson
Some sata drives will have a jumper on the drive which will speed limit to 1.5GB/s. Depends on which drive you are buying.
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
tib2220
Sep 14, 2015 12:33 PM
