`90spec Series2 StripDown
Car Started as this:
Pretty much a standard Series two with a few shiny bits.
Loved the car, using it daily up until about 18months ago. Unfortunately living near the coast and being 18 Years old the cursed rust/rot has got the better of it.
Decided to go bare shell and do a proper job first time, but we`ll see how that goes
Thanks all!
Been following a couple of long term threads on here, Twins especially,
motivated me to get on with mine. Spare time allowing, it might take a while but hey, it`ll get there.
The engine hasn`t run in so long it tried to fly off the minute the gearbox was removed,
stopped its bid to escape and bolted it down
motivated me to get on with mine. Spare time allowing, it might take a while but hey, it`ll get there. The engine hasn`t run in so long it tried to fly off the minute the gearbox was removed,
Pulled out the interior,
How easy (or not!) is it to put the dash back in and not trap any of the wiring?
Have a feeling that will be fun!
floorpans are pretty good. One small bit of rust near one of the seat mountings but better than expected.
The rest of the drivers side however is a different story. I will try and get better pics tomrrow but these just about show the problems.
Arch has rotted at every mounting point for the bodykit, guessing it had a wing change at some point
Nice hole in battery tray and firewall/bulkhead beneath it.
I really need to work on my photography
Sunroof seal had gone leaking water into everywhere, this is a big problem as the rail the sunroof sits in and the screws which hold the glass in are all rotten
When I pulled the headlining out a nice shower of rust follwed it.
The other problem due to above is where the water goes afterwards, following gravity as so:
Havn`t a photo yet but there`s a nice big hole in the lower rear wing/sill join, aftermarket drain hole we`ll call it for now.
Have a feeling that will be fun! floorpans are pretty good. One small bit of rust near one of the seat mountings but better than expected.
Man, thats bad!
I have only ever seen rust like that in one other S2 that was a D plate we bought to break and had had a quarter panel very badly fitted at some point.
The other quarter was mint.
It looked like yours from the outside but was rotten all over to the point you could push on the panel and hear the rust falling off and into the sill cavity!
Originally Posted by RAT8OY
Man, thats bad!
Am looking at reshelling at the mo. Although possible to change roof skin, rear wing etc, Be nice to have it back for summer.
No, sunroofs still in. Going to have to drill the screws out soon.
Prob will reshell but if I can save it? Is it worth it?
If I was a little more confident with the mig and able to paint, it would be done by now.
Cut front wing off anyway and inner is fine, parts of the car are mint, others past it, weird.
id say it really isnt worth it, (even though i hate the thought of scrapping a s2) but the roof has gone which means new roof, drivers side rear quarter (if you can find one) then sills wings , front panel, much easier to find a nice shell, could pick one up for a couple of hundred quid. contact one of the breakers mate. let us all know what you decide.
cheers mark.
cheers mark.
Bearing in mind if you do shell it, you use the id and plate off the other shell you use .if you dont want to reshell,stuff like quarter panels etc find a minter in the scrappy and cut them off and re use them and the roof ,its not that hard to do ,that way you keep your original shell
I would love to replace all the panels myself, bought a front wing and battery tray already. Realisticly I don`t have the skill or time to do the roof and I`m betting a rear quarter isn`t easy.
As said a new shell means new vin but could I transfer the Reg to the new shell??
Anyone hears of a nice shell, finders fee offered!
One of my old S2's rotted in exactly the same places mate
Roof was every bit as bad as yours and drivers side rear wing just below the window edge was prob worse than yours !!!! Ended up just filling the roofskin and managed to cut out and replace the top section of the rear wing, used plenty of rust treatment and the roof repair lasted for a good few years before the car was eventually scrapped
Shell is def worth saving yet mate if you are keen enough and patient enough to repair it
Northern Bloke
67
Apr 14, 2009 03:17 PM
McCloud 85
25
Jun 18, 2005 07:00 PM
thats bad. never seen that before. best of luck with it mate
