Cosworth cylinder head differences.
Old Jan 11, 2008 | 06:01 PM
strimmer_monkey5's Avatar
strimmer_monkey5
Default Cosworth cylinder head differences.
Hi there. i know there was a post before about this but spent ages tryin to find it with no luck.
Im just wondering what the difference is between the 3door, 2wd, 4x4 and rs500 cylinder heads are..
The head i have has got lugs for the turbo damper and its got 3 holes for the thermostat housing.
any info really appreciated. Thanks.
Old Jan 11, 2008 | 06:31 PM
s2 scottys bitch's Avatar
s2 scottys bitch
Hi ya mate..
As far as i know the 2wd head as a two bolted thermostat and yeah 4x4 as a 3 bolted one.. i dont think there much differents apart from that as i had a f reg 2wd saff with a 4x4 200 block runing a 2wd head , a 4x4 exhaust mainifold and turbo which i belive gave more bhp...
s2 scottys bitch
not sure on rs500
Old Jan 11, 2008 | 06:34 PM
cossied's Avatar
cossied
Default head
A 2wd can have 3 studs on the thermostat if is a later one. A 4wd has no lugs and an oil feed out to the Turbo about half way along.
Old Jan 11, 2008 | 07:12 PM
Aaroncast's Avatar
Aaroncast
tops are different on the later escos's two coils in head appature!!
Old Jan 18, 2008 | 12:47 PM
davidreader5's Avatar
davidreader5
Hi,
Also if fitting 2wd, head to 4/4 block, or 4/4 to 2wd, block you have a different comp/ratio.
Regards Dave R.
Marcus L
Aug 29, 2015 02:18 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
turbotrev
Aug 22, 2015 11:41 AM
Aug 14, 2015 07:29 AM
Bobby9779
Aug 11, 2015 06:47 PM
