smoking?????
Old Jan 8, 2008 | 07:42 PM
chris series1's Avatar
chris series1
Default smoking?????
i have a series1 and it seems to smoke badly wen the engine is on over run, for example, down hill in a low gear, any ideas any1??
Old Jan 8, 2008 | 09:31 PM
mechanic28's Avatar
mechanic28
would try valve stem seals first fella,common on the cvh and easy to do
Old Jan 9, 2008 | 11:38 AM
picky775's Avatar
picky775
sounds to me like sumone has fooked there turbo
Old Jan 9, 2008 | 11:54 AM
chrisyturbo1's Avatar
chrisyturbo1
could be the piston rings are shot
Old Jan 10, 2008 | 03:29 PM
mikedaf2's Avatar
mikedaf2
two choices there mate valve stem oil seals or turbo if it smokes alot when you start the car from cold its more lightly to be the valve stem seals if not its the turbo.
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
