how vital is it to balance a turbo
my turbo is a bit smokey so was gonna rebuild with new seals from garret with one of these kits that they do but a few people have said you have to get it balanced or it will be shagged in no time, so guys whats the score is it pretty vital?
cheers guys
cheers guys
Originally Posted by J871yhk
they do about 120,000 rpm...
Do you think it wobbling a bit and then shatting the compressor wheel, which would send metal lumps into your engine is a good idea?
Alex
Alex
PassionFords Creator
But then you must ask yourself:
"If i replaced all parts of the rotating assembly exactly back as it was when i started, will the balance have changed at all anyway?"
Interesting question....
exactly stu. as i understand it, you just remove the compressor wheel from the shaft to change the seals and then put it back on at the same angle and nothing should go out of balance.
i read an article on the net somewhere that explained how to do all this. do a google search mate.
I read some where that most turbos do require a balance after a rebuild however with Garratt turbos you can get away with out balancing as they as Garrett balance each component of the shaft assembly independently so no matter how you put it back together it should still be in balance.
I'm not saying its gospal but worth looking into?
alot of conflicting arguements here
stu im gonna ignore your your comment even though its valid as its you im gonna be getting the repair kit off and you know it
Listen to stu...
What get balanced is the shaft n wheels, so how in fuck can changing the seals make it need re-balancing?
It neededing to be rebalanced is just more bullshit companys tell you to justify the prices they charge...
i rebuild my turbos myself , have done for a while , all the parts that come for my garret turbos are individually balanced anyway , its a bit like , taking a tyre off the rim , as long as it goes back in the same place nothing will change !!
out of curioscity, how accurate do you have to be on re-assemble?
if the thing was say 1mm out would it feck stuff? or have you got a bit to play with?
ive never dismantled a turbo or anytihng, just always wondered....
or can they only go back together one way, so you cant get it sightly off?
well i ordered the repair kit earlier from motorsport developments so ill let you know how it goes, if it all goes pop you know it needs to be balanced
Cheers matey.
p.
JK12
33
Apr 26, 2021 12:09 PM
