erst diff bearing race sealant
Old Jan 5, 2008 | 09:51 PM
Moondust_crust's Avatar
Moondust_crust
Default erst diff bearing race sealant
putting new lsd diff bearings in the gearbox im rebuilding, one of the races for the back of the diff seems to spin in the box is there anything i can put on the back of it to stop it spinning
Old Jan 6, 2008 | 08:11 AM
There are specific sealants for this, but if spinning in the housing with no load, surely it's not the problem ?
The sealants are called BEARING FIT, I think(?) Loctite do one 01442 278100
Old Jan 6, 2008 | 01:41 PM
Moondust_crust
will it sort itself out then once its all back together and the diff is in there or should i get some stuff for sealing it in?
Old Jan 7, 2008 | 06:33 PM
groomers's Avatar
groomers
i would put a little bearing set on it for peace of mind. sorted out the rear hub on my cabbie when that wore out!
Mc5506
Oct 5, 2015 09:57 PM
89barto89
Oct 4, 2015 06:59 PM
The Youth.
Sep 30, 2015 09:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
