cossie died on me!!!!!!
Old Jan 5, 2008 | 05:27 PM
mikelomax's Avatar
mikelomax
MOUSE
Default cossie died on me!!!!!!
it died on me whilst out thrashing it today at about 7000 rpm in first gear.
i have narrowed it down to the fuel pump, it will only prime when i connect a live wire to it but not from the ignition.
i have checked for a loose fuse or relay in the footwell but all seems fine, could the relay have died on me, (is it the green one???).
or if not what could it be.
regards
mike
Old Jan 5, 2008 | 06:06 PM
mechanic28's Avatar
mechanic28
crankshaft sensor gone down poss
Old Jan 5, 2008 | 06:42 PM
The fuel pump relay is yellow mate. Well it is on a 4x4 saff. If you have got a faulty crank sensor or crank sensor connector the engine ecu wont pick up the signal so then the fuel pump wont prime. Put if it was the crank sensor at fault it wouldnt start. When i first got my cossie i got told to replace the fuel pump relay cause its a common fault and they stop working apparently.
Old Jan 5, 2008 | 07:38 PM
Alvyn's Avatar
Alvyn
has the fuel cut off switch in the boot been triggered? has the crank pulley got ALL 4 lugs?
Old Jan 6, 2008 | 08:18 AM
You don't say if the engine starts when you connect direct to pump ?
If it does then the fuel pump is ok at least.
Have a wiggle on the CPS connector first, there is no reason other than crank walk why the cps would be damaged, but if it had this much walk your engine would be all over the floor anyway!!
The prime only works under certain conditions, cehck as said the cut off, some people even wire the pump through relay direct to ignition, still goes through, cut of so safe.
Old Jan 7, 2008 | 08:02 AM
mikelomax's Avatar
mikelomax
MOUSE
where is the cut off switch????
mike
Old Jan 7, 2008 | 09:05 AM
timster's Avatar
timster
mike
Under your spare wheel mate,if i remember its a red bit of plastic but can't remember if its up or down and check spades haven't come loose inside
Old Jan 8, 2008 | 05:07 PM
stickertone's Avatar
stickertone
its in one of the front footwells on a 4x4 saff
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
