1 for the ZVH owners,or folks in the know...
Old Jan 3, 2008 | 09:18 PM
warleydaddy's Avatar
warleydaddy
Default 1 for the ZVH owners,or folks in the know...
Ok,if i go for a 1.8,or 2.1 ZVH conversion...What else am i looking at,bar buying a built bottom end???
What turbo?
Do i need to do anything to the head?
What chip?
What injectors?
And anything else you can think of,off the top of your heads???
Cheers in advance..
Pete...
Old Jan 4, 2008 | 12:06 AM
ram's Avatar
ram
Has a large member
literraly just finished my 1.8zvh frst today but couldnt get it started up due to some fresh electrical problems
nothing needs changing to the cvh head fitting wise (except to use longer head bolts), its not essential but zvh's react well to some head work. although mines standard except for being gas flowed.
if your buying a ready built zvh bottom end then all the cvh bits pretty much bolt straight on. the only things i had to do was open up the cvh flywheel bolt holes slightly, and use a 1.3 cvh cambelt tensioner (costs £50 from ford ). some ppl say the 1.6cvh tensioner fits if you mount your water pump at an angle, but the 1.6 one physically wont fit because the wheel touches the top pully.
all in all its a dead easy conversion to do. infact i found the t3 conversion more hassle to do parts wise
as for chip and injectors - im using beiges and a 195chip, im hoping for a reliable 200bhp at about 14psi.
the 2.1zvh conversion has a bit more involved in it than the 1.8 but il leave that for someone else to explain as i havnt done one.
let me know if you want any more details.
cheeRS.
Old Jan 4, 2008 | 06:37 PM
jacko's Avatar
jacko
the 2.ol is exactley the same baring you need the sump oil pump and pick up from a 1.8 front wheel drive you will need an escos fuel pump bages and a 195 chip
should end up with one of these done ,one we done latley
Old Jan 14, 2008 | 12:19 AM
RS EDDIE's Avatar
RS EDDIE
Mate speak to guy turner at burton performance in ilford, hes your 2.1 ZVH man!
Just not on a monday morning tho!
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
