Rear beam and discs
Old Jan 3, 2008 | 07:13 PM
Rippers's Avatar
Rippers
Monte Geek
Default Rear beam and discs
What routes are there?
Old Jan 3, 2008 | 09:49 PM
Wardy257's Avatar
Wardy257
Dont waste your time. The rears only do 10% of the braking anyway. Even if you find a way of fitting them you will end up reducing the rear bias so much they will have the same braking power as drums.
Old Jan 4, 2008 | 09:47 AM
Neil@FastFord's Avatar
Neil@FastFord
I have an RS2000 set-up on mine Paul.....no bias and it's fine. I have Hi-Spec 4 pots on the front and it brakes like fook!
Old Jan 4, 2008 | 09:56 AM
Luca's Avatar
Luca
Lukesville
If im honest i didnt notice any difference in fitting rear discs with regards braking performance....
i purchased the kit from Fiesta centre.... comes with everything bar the 2wd cossie calipers which i got from Ford.
The main reason I did this is once fitted on the car it widens the rear track
also the added benefit of looking nicer...
With race spec pads up front and standard cossie mintex in the back if the brakes are not warmed up the rear will lock... once warmed though stops immediatly with no locking .... no need for a bias valve.
For an every day road car i would recommend some standard compound pads and then change for track use
Old Jan 4, 2008 | 10:01 AM
Luca's Avatar
Luca
Lukesville
missed the rear beam part there.......
as for rear beam set up there are a few ways to go...
1)standard rear beam poly bushed..
2)standard rear beam with twin anti roll bars fitted.
3) fit the stiffer zetec-s rear beam..
personally I run the standard at the moment with poly bushes...
If I changed I would go for indepndant arms.. but thats along way off at mo... Biggest change is messing around with the poundage of springs to get the desired feel from the backend..
Old Jan 4, 2008 | 10:30 PM
KEVFRST's Avatar
KEVFRST
Focus Hubs/carriers & calipers
RS2000 Handbrake cable
MK5 Fiesta Handbrake lever
Mk3 Fiesta Front brake hoses
Job done.
Old Jan 4, 2008 | 10:46 PM
Luca's Avatar
Luca
Lukesville
Job done.
Whats the difference between the mk5 handbrake lever
Old Jan 4, 2008 | 10:49 PM
KEVFRST's Avatar
KEVFRST
easier to adjust, no more scambling about under the car. Simply do it from inside. Does away with having to mate the Mk3 adjuster mech to the RS2000 cable too.
Old Jan 4, 2008 | 10:56 PM
Luca's Avatar
Luca
Lukesville
good tip that cheers mate
Old Jan 6, 2008 | 08:34 AM
Oranoco's Avatar
Oranoco
Leave the drums in place mate.
The rear brakes do so little of the overall braking it just isn't worth the time and expense changing them to something else which can cause an overbraked rear end and a large hole in th elocal scenery
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
